Nexiq usb-link2
justimpact
Vehicle: ford F-350 6.7L diesel 2015
Nexiq usb-link2
Post by justimpact »
Hello all I have seen and used the ford VCM II but no longer have one. However I do have a NEXIQ USB-LINK 2 with the OBD2 adapter but when I attempt to connect it will say no adapter found. Any advise on how to make this work?
Re: Nexiq usb-link2
Use Google and use the search terms "NEXIQ USB-LINK 2"
You will need to visit this site:
https://www.nexiq.com/Document/Detail/232
If it's a clone, you're on your own.
It is only a J2534-1 implemtation and it may not access the Medium Speed Network
Use this image to access the device with J2534 within FORScan
Read this link as well:
viewtopic.php?f=4&t=867
Post your tests and results.
justimpact
Re: Nexiq usb-link2
thank you ill try it out in the AM and see how it works
