Forscan work on surface laptop?????
Sthomasson72
Vehicle: F150 3.5 powerboost 2021
Post by Sthomasson72 »
Microsoft - Surface Laptop Go - 12.4" Touch-Screen - Intel 10th Generation Core i5 - 8GB Memory - 128GB Solid State Drive - I
Will the software run on this computer
Re: Forscan work on surface laptop?????
The assumption is a W10 operating system. Download FORScan and install the application.
With the hardware number, generated a temporary license key.
Follow this guide and read the many posts within this site
License how to.pdf
(493.48 KiB) Downloaded 14 times
If you purchase a device to attach via USB or Bluetooth, consider one of these.
OBDLink EX
https://www.obdlink.com/products/obdlink-ex/
OBDLink MX+
https://www.obdlink.com/products/obdlink-mxp/
Use their drivers and make sure the latest firmware is up to date
If it all works, use screen capturing software or the one used with windows.
Snipping Tool.JPG (63.81 KiB) Viewed 258 times
Post your results
