No Adaptor Found Message
IFixHD1
Vehicle: 2009 Ford Escape 2.5
Post by IFixHD1 »
Hoping to get some guidance here:
Using Windows 10
Using a Modified ELM OBD Interface
Loaded Driver
Created a ForScan account
Received Approval and activation
Downloaded v 2.3.41
Installed Extended License Key active through 08/10/2021
Connect to the OBD connector.
Connect to the USB port on the PC.
Ignition on but vehicle not running.
Click "CONNECT TO VEHICLE"
Receive message "No adaptor found. Please check connection and try again"
Thoughts, suggestions or resources that may help me resolve this connection issue.
Thank you,
Dave L.
Re: No Adaptor Found Message
