Page 4 of 16
Posted: Sun Sep 11, 2016 2:43 pm
by mrclean64
Gatordog wrote:
FORScan wrote:White label solutions:
I did see this link to a ELM327 on this forum: http://www.totalcardiagnostics.com/shop ... 2-scantool
The prices are very similar, just wondering which one is better for Forscan on a Windows PC and being used on a 2000 F-350 7.3 Powerstroke diesel dually.
I already bought a china one and it works, but Forscan gives a fault code "clone"
This one works perfectly.....good price as well. I have purchased it and used it, and confirm that it works.
Posted: Mon Sep 19, 2016 1:49 pm
by mleady
Are the obdlink my wifi ones working with forscan yet?
Posted: Sun Oct 09, 2016 4:50 pm
by pez
[quote="mleady"]Are the obdlink my wifi ones working with forscan yet?[/quote
Just bought one assuming it was... 2017 Ford Escape. Reads modules fine, connects fine, but cannot reliably connect to MS-CAN and program central car configuration. Speed shown seems to vary significantly from connection attempt to connection attempt - sometimes in excellent range, sometimes good, sometimes poor. Sometimes when attempting to load CCC, gives error about poor quality adapter. Foolishly, I tried again after reconnecting, and got:
Central configuration (Main) has been started
Read configuration from primary module...
Loading SBL to primary module...
Loading block 1/6...
Operation failed, retrying...
Loading SBL failed
Service procedure has been interrupted
Sooo, hopefully everything still works. Just ordered an ELM327 adapter with switch from elm-327.eu - hopefully that works properly.
Posted: Sat Oct 15, 2016 8:23 pm
by madmalkav
Hi people. I need an interface for my 2001 Mazda 323F BJ 2.0 VDTD . For what I read in this thread, I think some of this should work, can anyone please confirm?
https://www.amazon.es/gp/product/B00OXX ... EMAP3&th=1
https://www.amazon.es/dp/B01B4EBYSM?psc=1
https://www.amazon.es/Vgate-Bluetooth-a ... gate+icar3
Also, are the BT adaptors fully compatible with the PC version or do I need an USB adaptor for that?
EDIT: bought the first one, seems to work OK.
Posted: Sun Oct 23, 2016 9:13 am
by smouser
I bought this one in the UK
http://www.ebay.co.uk/itm/181457166623? ... EBIDX%3AIT
It works perfectly on Ford Ranger 2016.
Posted: Thu Nov 03, 2016 8:06 am
by TimFor
Posted: Thu Nov 03, 2016 8:22 am
by TimFor
FORScan wrote:Basic recommendations are:
1. ODBLink MX (expensive solution), or may be cheaper alternative that use STN1170/STN2120 family (ELS27, Viaken etc...)
2. J2534 (expensive solution, also majority have no MS-CAN support and BT interface, so only applicable for Windows version) - CanTieCar, VCMII etc
3. iCar v1/iCar v2 (not v3) - cheap, but no MS-CAN support (that may be necessary for vehicles after 2004)
4. Special "Ford" adapters with mechanical HS/MS CAN switch (still no guarantee it will work stable), but NOT F-Super
5. ...?
Could you please explain why not F-Super? Would http://www.ebay.co.uk/itm/Ford-USB-F-Su ... 1802819528 work with Forscan?
Posted: Thu Nov 03, 2016 5:24 pm
by fred08155
F-Super is not based on ELM327, It is also not compatible with ELM327.
There is a device out there that is called "F-Super2" that has some features of ELM327 but does not support all protocols. F-Super 2 might work with FORScan but also may fail in some situations.
Posted: Fri Nov 25, 2016 11:51 am
by ClockWorK
Black Friday 33% discount on Scantool MX (Bluetooth) or MX WiFi code earlybird33 at checkout www.scantool.net
Not sure when it expires.
Posted: Sun Dec 04, 2016 5:12 pm
by laupetre
I just bought this one, working perfect on my 2013 Edge (both HS and MS). I just disabled BLISS as I had a bad module (useless feature for me anyway)
http://www.ebay.com/itm/272329308976
