New ECU on Mazda 3 - get unable to connect to vehicle
jeffmcewan
Vehicle: Mazda 3 2.5 2008
Post by jeffmcewan »
I purchased a new ECU for my Mazda 3 and need to reset the keys to it. I can connect fine to the old ECU, but after installing the new one it won't communicate.
Re: New ECU on Mazda 3 - get unable to connect to vehicle
You need to program the new PCM to the Mazda with a subscription. They come blank.
https://www.mazdaserviceinfo.com/pcm-reflashing
Either a VCM 2 or J2534-2 device is required.
jeffmcewan
The ECU was already programmed by the seller with my VIN. I would expect I could program the keys to it.
Then contact the seller, I'm sure the answer will be quite interesting.
