Obd link ex activation code
Butterbean182004
Vehicle: F250,6.7,crewcab/2021
Post by Butterbean182004 »
Where do I find the activation code for a obd link ex ?? I’m new to all this. Thanks for your help. Do I have to plug into truck first to get it ?? Thanks for the help
Re: Obd link ex activation code
Not sure what you mean by "activation code" but this site has support and drivers:
https://www.obdlink.com/support/ex/
Load the drivers they suggest.
If using FORScan, it needs to be installed as well.
Attach the cable, then attach the OBD end to the data link.
There's lots of reading material here, take the time to read it.
Start at the beginning:
viewforum.php?f=5
smartguy69
Post by smartguy69 »
Butterbean182004 wrote:
Tue Apr 27, 2021 3:07 am
There is no activation code for the obdlink ex. Read the white card that came with the device. If you plug the EX into the laptop and the light turns from red to yellow then the correct drivers are installed. If it stays read then go to scantool.com and download the latest driver.
