Forscan 2.4.x - UCDS pro +
Re: Forscan 2.4.x - UCDS pro +
davetcollection wrote:
Thu Jun 17, 2021 1:15 pm
Ecmbuster wrote:
Thu Jun 17, 2021 1:40 am
mag106 wrote:
Wed Jun 16, 2021 4:27 pm
Looks like my clone is too bad to support j2534, does not connect :x Image
You proved the chinese clone is another POS (Кусок дерьма). Well done!
I rest my case
Agreed and read the entire "piece".
mag106
Vehicle: Focus 3, 2.0 PS, седан, 20012г.
Post by mag106 »
Ecmbuster wrote:
Wed Jun 16, 2021 4:14 pm
Load the software that is with the UCDS, apply the drivers when connected.
If UCDS is a true J2534 adapter, use this setup with FORScan.
If it is not connecting, then the clone is not a true J2534.
in general, everything is fine, the seller sent a new installer - everything worked
2021-06-19 222904.jpg (242.85 KiB) Viewed 264 times
Isn't that one of those chinese clones that uses tokens?
V1.26.008 is very limited and quite old.
If the clone works like a J2534-2 and all the networks are accessed, then you have a working tool.
If you are looking for support, FORScan needs to be converted to English or take your messages on the screen and post them in English.
Creating another post specific for your faults and concerns should be created.
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Post by davetcollection »
My UCDS clone used to show up as FTDi so it was obviously an ELM327.
But it didn't work properly, it would read some modules and clear DTCs in those modules but nothing else
