els27
smegun
Vehicle: 2002 lincoln ls sport 3.9
els27
Post by smegun » Sat Jan 25, 2020 2:13 am
elS27 stn1170 with ftdi wont connect to my 1st gen Lincoln ive tried to update the 1170 but the firmware is a mismatch and wont finish flashing the chip my question is to try and get this to work with a version of forscan maybe not a current one or flash the ELS27 to a proper version number of which I was told 4.2 x or higher will work
any path is an ok path to try let me know if you got a firmware to flash or that I can find a version of forscan that will work with the unit for some mysterious reason the disk that cam with the adapter had a bad software disc and I couldn't use the version recorded on disk the comment originally on the site was to not get upset and download the software from a given link which also didn't work so Im burned but vars don't know _hit really
