driver install.....
Diesel D
Vehicle: 2002 Ford F-350 7.3 Turbo Diesel
driver install.....
Post by Diesel D » Sat Nov 09, 2019 9:21 pm
my computer won't install or recognize the driver that is associated with forscan. Then when I plug into the OBDII port on my '02 F-350 7.3....it doesn't recognize forscan. I have forscan downloaded onto my computer, and have the trial license. what do I do?
Vehicle: *** Ford ***
Re: driver install.....
Post by f-wolf » Sat Nov 09, 2019 10:02 pm
Just have a look here ...
Maybe this will help you
(If ELM327 USB isn't setup properly as per instructions below — then OBD software will not even detect the cable — let alone connect to the vehicle.)
Diesel D
Post by Diesel D » Mon Dec 02, 2019 8:31 pm
thanks for the link, f-wolf.....it took a while, but I got it to work....my codes are as follows.....IC : U1027, U1262.....PCM : P1280, P0603.......not sure what to do after that....any suggestions?.....thanks.....
Post by f-wolf » Tue Dec 03, 2019 8:11 pm
Trouble Codes
Read more at: https://www.obd-codes.com
Diesel D
Post by Diesel D » Wed Dec 04, 2019 1:31 am
thanks f-wolf.....you are a gentleman and a scholar....... :D
