Service Procedure has been interupted
gplavergne23
Vehicle: Ford F150 5.3 V6 2013
Post by gplavergne23 » Sat Sep 21, 2019 1:31 am
Newbie here, I have a 2013 F150 Platinum with a tire pressure sensor light on that I am trying to remove.
I am the newest Beta EL version of Forscan (2.3.24) and I am using a WIFI FORScan OBD2 Adapter, OHP ELM327 connecting via WIFI.
Everything works great until I am in the "Configuration and Programming" section, when I disable the TPMS and "write" it goes to 50% then gives me this error code:
18:14:24:241 This adapter has CAN bus compatibility problems and can not be used in some functions
18:14:39:400 Service procedure has been interrupted
Before assuming I just need to buy a different module (possibly a usb or a bluetooth) i wanted to confirm that it is just my junky OBD2 adapter.
Appreciate the help! Hopefully I gave enough info
denbo
Vehicle: ford focus 16 zetec
Re: Service Procedure has been interupted
Post by denbo » Wed Oct 09, 2019 1:57 pm
I have never had any success programming with bluetooth. With USB, no problems.
Andyfocus
Post by Andyfocus » Thu Oct 10, 2019 2:22 am
programming is disabled with wifi by default due to drop outs and other wifi problems to stop people from bricking thier modules .
it is in the release notes.
