Traffic sign recognition on Fiesta MK8 >2017
roylion15
Re: Traffic sign recognition on Fiesta MK8 >2017
Post by roylion15 »
Now
IPC
720-01-01
factory
044A 3464 20 to 044E 3464 22
for AHB menu + IPC light.
BCM
enable AHB + LF AHB usage
726-11-04 3102 0241 E1
726-11-04 3101 02C1 E1
RF AHB usage
726-12-02 0202 1200 02
726-12-02 0102 1200 02
Note : You can change the settings in BCM with "direct configuration" instead of ASbuilt values , same results...
1) Enable AHB option
2) LF HB usage set AHB
3) RF HB usage set AHB.
Tatore87
Vehicle: FORD FIESTA
Post by Tatore87 »
Thank you!!!!! everything works
I wanted to ask you one last question do you know how to activate the rear view camera?
roylion15
Post by roylion15 »
Hello
Very happy for you !
Do you talk about an aftermarket composite cam ?
Need some work / hardware to the vehicle but I can give the settings only if you have a SYNC 3 APIM .
Do you have already factory parking aid ? ( sensors ) ?
Note that I can check with your VIN if this modification is possible.
Tatore87
Post by Tatore87 »
I would like to buy a used original
I already have parking sensors as standard but I don't see the apim module
https://ibb.co/z6rM7hr
https://ibb.co/qYhZfgv
https://ibb.co/bv4gYdM
roylion15
Post by roylion15 »
Hello
Bad news ...
You don't have SYNC 3 but the basic SYNC, thus no APIM module.
it's not possible for me to add a backup camera "original" or "not" ....
kowalsfee
Vehicle: 2020 ESCAPE
Post by kowalsfee »
roylion15 wrote:
Wed Mar 11, 2020 8:56 am
Hello
Bad news ...
Hello there,
I own a 2020 ESCAPE ST-Line Asian model,built with ACC with stop and go ,AHB,LAK, but no traffic sign recognition.
I succeeded programmed IPC with forscan latest version and had TSR menu activated, however TSR was not working, not showing any signs but only with 2 empty circles in my panel.
After reading all posts,I checked my camera part model,which is described as" LV4T-19H406-EF". Strategy: LV4T-14F397-GF,Calibration: LV4T-14F398-GF
So I'm asking, how could I programmed IPMA to make TSR working ?
706-01-01 factory setting is 0426-BDC9-A9.
Hope to get some help, thanks!
roylion15
Post by roylion15 »
Hello
@kowalsfee
Check that ...
TSR fusion mode if navi present in sync 3
0426 BDDA A9
TSR camera only if no navi sync 3
0426 BDD2 A9
jloisa
Vehicle: Ford Fiesta 1.0T A6 ST-Line 2018
Post by jloisa »
Is there a setting that defines how long the recognized sign is displayed on the screen?
My 2020 ST (with SYNC 3.3 though) shows the speed sign a bit too short time, f. ex. 80km/h the recognized sign is displayd bright for 1km and the turn grey and after another 1km it disappears. The lower the speed limit the shorter the time/distance it's displayed.
roylion15
Post by roylion15 »
jloisa wrote:
Tue Apr 21, 2020 6:24 am
To my knowledge, there is no adjustment for this...
jloisa
Post by jloisa »
roylion15 wrote:
Tue Apr 21, 2020 12:32 pm
Ok, damn. MY2019 cars seem to keep the sign in the display a lot longer than newer models. Something has changed.
