Auto Unlock 2007 Ford Expedition
pc3332132
Vehicle: Expedition, Gas, 5.4L/300 hp, 2007
Post by pc3332132 » Fri May 24, 2019 2:08 am
Hi I am trying to figure out if it is possible to add the auto-unlock feature to my 2007 Ford Expedition XLT. It came with the auto-lock feature but I would like it to auto unlock like my 2007 Ford Explorer Limited if possible. I also recently drove a 2008 Ford Expedition Limited that had the auto-unlock feature as well so I got the VIN and looked up the as-built data for both the 2007 and 2008 Expeditions. So far I have not been able to figure out what section in the IC(instrument cluster) that I need to change to enable this feature or if it is possible.
I have both the FORScan and Ford IDS software w/VCM II as well as access to Ford AS-Built information.
Thanks for any help or guidance you can give.
biggorillas
Vehicle: fusion, 1.5t, 2014
Re: Auto Unlock 2007 Ford Expedition
Post by biggorillas » Fri Aug 23, 2019 5:01 am
Dose your ipc have the Auto Unlock option In the settings? My 07 has it but it doesn’t seem to work at all.
ThatOneDude
Post by ThatOneDude » Fri Aug 23, 2019 6:23 am
After looking through the owner's manual for 2007s and 2008s, it looks like this was not a feature in 2007 at all, only added for 2008.
Wouldn't recommend actually trying this, but a GEM/SJB swap from a 2008+ might get you features that were added to later years.
pc3332132
Post by pc3332132 » Sat Aug 31, 2019 3:10 pm
No, It only has the Auto Lock option. I would be interested in seeing the as built data on your vehicle to see how it compares to mine.
pc3332132
Post by pc3332132 » Sat Aug 31, 2019 3:11 pm
I wonder if it's just a as built programming difference or if the modules are physically different?
ThatOneDude
Post by ThatOneDude » Sun Sep 01, 2019 8:59 pm
I looked up parts and the GEM is part number 15604. I found 4 different versions for vehicle manufactured between these dates.
08/02/2006 - 12/06/2006
12/06/2006 - 11/10/2007
11/10/2007 - 06/29/2009
06/29/2009 - 01/04/2010
