2013 ford f250 gas 6.2l - Deletle or disable tpms
mpittakas
Vehicle: 2013 ford f250 6.2l gas
Post by mpittakas » Mon Apr 15, 2019 1:58 am
trying to delete tpms
i have code of B12D ?
Need help to disable or delete tpms tire monitior system ?
i looked ar 726-02-01 but i have 0A3A .. i changed like forum user to 0030 and didnt work.
please adviced
also i dont have gem/stb field .
redrussell
Vehicle: ford f250 ,6.4 liter 2008
Re: 2013 ford f250 gas 6.2l - Deletle or disable tpms
Post by redrussell » Sat Aug 31, 2019 4:33 pm
i am not sure if its the same lines as a f150 2014 but i just turned them off tpms.
line for my truck 726-23-01 first set of numbers read 0101 changed to 0000 write and it works great
redrussell
Post by redrussell » Sat Aug 31, 2019 4:37 pm
also in my f250 2008 the lines you changed.
i changed 0000-0000-0000-0030
worked on my f250 its in the gem
redrussell
Post by redrussell » Mon Sep 02, 2019 11:59 am
if theres no gem look for bcm
lenko
Post by lenko » Mon Sep 02, 2019 2:11 pm
On a 2012 F150 it was 726-22-01 x0xx xxxx xxxx. Whatever number in the second position make it 0. May be the same on a 2013.
