2019 Expedition
banmidou90
Vehicle: 05 explorer 4.0l 4x4
2019 Expedition
Post by banmidou90 » Fri Apr 12, 2019 3:08 pm
Turned off BMS in BCM to disable start/stop and now when u start the vehicle the check charging system message pops up in message center I used the template for F150 to disable it but trying to program IPC it wouldnt go thru could this have something to do with it I have 2 to fix please advise if yall have ran into this
twisterrescue
Vehicle: 2003escapeltd
Re: 2019 Expedition
Post by twisterrescue » Fri Apr 12, 2019 11:51 pm
I hope you followed .The rules and saved your file .For the bcm before mod. was done . if not go to motorcraft service .site enter vin# it will allow you to download the asbuilt file .reload the file it will put truck back to stock .your truck & the navigator .Are all new in 2019 thus little has been found .in code,s .you will have to wait .untill someone w/a higher level .this stuff play,s with these trucks
warrensauto
Vehicle: Expedition, 3.5L, 2019
Re: 2019 Expedition
Post by warrensauto » Sun Sep 29, 2019 7:05 pm
I have the same problem. System won't complete any configuration changes in IPC.
Tyler1011
Vehicle: Edge, 2.0l, 2019
Re: 2019 Expedition
Post by Tyler1011 » Tue Nov 12, 2019 4:15 pm
Any update on this issue? I have a buddy that asked if i can disable stop start on his 19.
30 RUM
Vehicle: F-250, 6.7L 10,000GVW, STOCK, 2017
Re: 2019 Expedition
Post by 30 RUM » Mon Dec 16, 2019 12:59 am
Any update on this? I get the same error with my 2019 Expedition.
