Page 1 of 2
Install cruise control cruise ecosport
Posted: Mon Apr 08, 2019 11:50 am
by Miecosport
Hello, I would like to install the cruise control system in ecosport 2015 that does not have this function. I would like to install the steering wheel controls and I wanted to ask for information on how to activate the speed control function through Forscan. I just bought an elm327 and I am a beginner, to learn I ask for advice to activate this function.
In configuration it appears:
APIM (AS BUIL FORMAT)
RCM (AS BUILT FORMAT)
ACM (AS BUILT FORMAT)
IPC (MAIN)
IPC (AS BUILT FORMAT)
As the configuration function is dangerous if you do not know what you are doing, I have not passed from here, and I would like information to learn and access safely. Someone could explain the steps to follow. Cruise speed control is activated / deactivated by pressing any icon, or it is necessary to rewrite some numeric code, in this case, how can I find out what numeric code would be needed to activate this function?
Thank you!!
Re: Install cruise control cruise ecosport
Posted: Mon Apr 08, 2019 11:58 am
by gg1234635
have a look at all the different information on there without making any changes. I would also suggest that you make backsup before you make any changes.
There are plenty of people that have created spreadsheets out there. Might be worth looking at the forscan guide group on facebook or on the g2fusions website. most of the ford coding is the same across all models with a few differences.
Do lots of reading before you make any changes.
Also use the site below for you to get your asbuilt data for your vehicle
https://www.motorcraftservice.com/asbuilt
Posted: Mon Apr 08, 2019 11:11 pm
by Miecosport
Hello, I have reconnected, in PIDs / IPC I have found WLS1CA active speed control in off state.
Then I have entered congiruración IPC / central configuration (main), forscan tells me that to use this function I need an extended license.
With the extended license will I be able to activate cruise control?
I ask this because the controls of the steering wheel for radio and telephone appear to me inside the FCDIM module interface of screen / front controls, and inside the configuration function FCDIM does not appear. Should I see more features? I use an elm 327 with original chip with automatic change ms hs. Will I have configured it well? since within configuration only APIM, RCM, ACM and IPC appear.
Did you also want to ask if the backup is done by pressing "registration"?
Thanks for your reply.
Posted: Wed May 08, 2019 9:15 pm
by Dessu
I have the same problem, my Cruise Control not work.
Posted: Mon Aug 12, 2019 5:32 pm
by Dessu
I have the same problem, my Cruise Control not work, anyone have success?
Posted: Mon Aug 26, 2019 1:13 pm
by ECORULES
I am in the same boat as you I guess, any luck with this ?
let me tell you where I am stuck.
Purchased the below.
1. OBD II : https://www.aliexpress.com/item/3282957 ... 4c4dN4sGtW
2. Cruise Control with Panel : https://www.aliexpress.com/item/3282869 ... 4c4dN4sGtW
3. Wire Cable as recomended by the seller: https://www.aliexpress.com/item/3287999 ... 4c4dN4sGtW
The attachment Eco 1.jpg is no longer available
Now I did follow all instructions as seen on youtube, disconnected battery, removed the Horn and installing the new set was a breeze actually.
Screw both the Audio and Cruise Control and plug in the wire along with the ground wires etc.
Even before I stared the replacement of parts I had used forscan and activated cruise control in BCM and if you look at image 2 you can see the little cruise control lit in Green behind the speed needle (Image 2).
Eco 2.jpg (194.12 KiB) Viewed 1604 times
All good here but what am I supposed to do about the 3rd (Wire Set) i purchased, it does say cruise control wire speedmeter cable signal harness for fiesta for Ecosport so look relavent but there is no option or instruction where do they go, there is nothing available within the steering and the cruise control switch where these will go (Image 3).
So after packing up, the light on the cruise control switch does work, but pressing the ON button doesnt bring any result.
Secondly I have seen SCCM (Steering wheel control) option on Forscan on many vehicles but fail to find this option on my Forscan list for my Ecosport. Maybe there is where you have the option to activate these switches ?
I am stuck here guys and any help is appericiated.
Car Details.
Ecosport 2016 India
Titanium AT 1.5 Petrol
Thanks !
Posted: Tue Sep 10, 2019 10:08 am
by Dessu
I have no solution yet :(
Posted: Sat Sep 28, 2019 12:25 pm
by Dessu
nobody can help us?
Posted: Tue Oct 29, 2019 1:11 pm
by LaForge
Hi Friends,
I dont have an Ecosport, but I have done it with my Focus.
You need the following being programmed with ForScan.
BCM
1. Cruise Control (you may already have done yet)
maybe: (you need this in a Focus)
2. ASL (automated speed limiter) ON/ENABLED
in EcoSport you see some of this configs also in IPC Module.
Please activate Cruise Control and maybe ASL also in IPC (if available)
(Sorry, I have checked with a 2018 Ecosport and this one needs both settings to be switched)
Then you have to do the following:
ABS:
Forced Module reset
Relearn vehicle data.
Then check the DTC section and reset DTCs
You have to drive at lease 30kmh otherwise the Cruise control cannot be activated
I hope it helps
Best regards
Karsten
Posted: Tue Oct 29, 2019 2:09 pm
by LaForge
Addition:
I have read you have to change values in 4(!) Modules to get Cruise control work.
(IPC, BCM, SCCM und PCM)
You need to activate Cruise control AND Speed limiter into this 4 Modules.
Then it will work.
Also you need the 8Pin Cable to get it work.
Best regards
Karsten
