Change Unit of TripTotal in IPC Focus III
Posted: Mon Mar 25, 2019 11:02 am
by LaForge
Hi there,
I have changed the fuzzle Trend IPC with the ugly mini display against a Titanium one with color tft screen.
It came from a Focus from GB
All went fine, but:
The TripTotal Value remains at Miles. All other values and units are changed to KM. Language was set to GER all fine, but the TripTotal remains at MLS
I guess the solution can be found in the asbuilt values.
Does anybody knows about it and can help me?
Best regards
Karsten
Re: Change Unit of TripTotal in IPC Focus III
Posted: Mon Mar 25, 2019 1:19 pm
by Andyfocus
if it came from a uk titanium check in the ipc unit setting and check if you can change all setting to kph from mph , shouldnt need forscan to do it if its a titanium from uk .i have zetec from uk and can select either mph or kph in the settings menu.
