Global opening and closing windows
kirkie
Vehicle: Fiesta Titanium 2011 1.6 Petrol
Post by kirkie » Sun Mar 24, 2019 10:10 am
Hi all.
First time poster here. :D
I was wondering if someone could help me.
I have used programming devices on a few of my cars over the years. So I am comfortable with them. I got my forscan tool yesterday.
I have enabled a few nice features already. Mainly the anti hijack and disabled the most annoying one. Gear change indicator.
I am stumped though. I wanted to enable the global open and close of the windows. But I cannot see the option to.
Am I being dim or is it definitely there?
Thank you all in advance
Kind regards
Sean
Don Ridley
Vehicle: 2016 Transit Connect
Re: Global opening and closing windows
Post by Don Ridley » Sun Mar 24, 2019 3:21 pm
All windows must have factory one touch open/close function for the global open/close to work.
prostkxy
Vehicle: XY Fairmont GS & Fuckass Trend shitbox
Post by prostkxy » Mon Mar 25, 2019 7:53 am
if its anything like the focus:
ignition on
make sure all windows are up
press and hold all 4 window buttons down
when windows are all the way down, hold down for 10 seconds
then hold all 4 window buttons up
when all the way up hold the buttons up for 10 seconds
let go of buttons
ignition off
lock the car with the button
then press and hold the unlock button and they should all come down.
if you only want 1 or 2 windows to come down, just use those buttons for programming.
hope this helps
mthurm7
Vehicle: 2013 ford focus 2.0 gtdi
Post by mthurm7 » Fri Jun 07, 2019 5:14 pm
attempted instuctions and global opening works but global closing does not work,
mthurm7
any advice will help
gg1234635
Post by gg1234635 » Fri Jun 07, 2019 5:18 pm
it should be an option on your IPC. If not look in the BCM module for it. I think forscan already have it as an option without needing the coding through asbuilt
Don Ridley
Post by Don Ridley » Fri Jun 07, 2019 5:52 pm
Global closing on vehicles sold in the US is not enabled by the factory. Use Forscan to enable. For Focus and other euro models look under Bdycm Main.
mthurm7
Post by mthurm7 » Fri Jun 07, 2019 9:00 pm
global opening was just enabled in bcm attempted training and only opening is functioning, what is the correct initialization to learn after activating?
Lee25
Vehicle: Focus Zetec, 1.6
Post by Lee25 » Fri Jun 07, 2019 9:05 pm
i don't think it can be done on your year of fiesta the facelift have different door modules which do have global open/close and are not interchangable as i have tried it out.
Derivel
Vehicle: Ford Fiesta 1.4i 97bhp 2009
Post by Derivel » Sat Aug 31, 2019 8:02 pm
I also have this problem. I could enable it in BCM, but the DDM and PDM modules are missing in my 2009 Fiesta, so it's not working. Is this because it's too old?
