.AB file
kingmobileaudio
Vehicle: FORD F150 3.5 ECO BOOST LOTS OF POWER 2019
.AB file
Post by kingmobileaudio » Fri Mar 22, 2019 7:57 pm
Can a .ab file form Ford be imported infor forscan?. I thought I did a stock backup.
gg1234635
Re: .AB file
Post by gg1234635 » Fri Mar 22, 2019 8:01 pm
Yea you can. You load up the config section in Forscan and do each module at a time using the same AB file.
Mark12
Vehicle: 2014 Ford Focus MK3 Titanium 1.0 EcoBoost
Re: .AB file
Post by Mark12 » Fri Mar 22, 2019 8:18 pm
When you are in the as-built programming section of FORScan and have selected the module you would like to reconfigure (as-built), select 'Load all'
Then in the file browser window that appears, navigate to the location of the as-built file - remember to select 'File type' from the window, and in the drop-down select .ab and the as-built file should appear for selection.
HankRGrill
Vehicle: 2011 Explorer V6
Re: .AB file
Post by HankRGrill » Mon Feb 03, 2020 3:57 pm
Why is this not working for me?
I have latest Forscan sw, extended license showing activated, Windows 10 laptop fully updated, good OBD unit with USB cable and switch, got the asb file from Ford site came in *.ab file format.
All I am trying to do is reprogram my replacement Sync 2 APIM and load the APIM module asb file. Do you have to reload other modules as well?
Thanks for ANY leads AT ALL.
smokeduv
Vehicle: Ford Fiesta ST turbo inline-4 1.6L/180hp 2014
Re: .AB file
Post by smokeduv » Tue Feb 04, 2020 1:34 am
Hi!
Will loading the ab file into forscan make a factory reset? I'm stuck with two codes after changing some codes. It was some minor stuff, but now I don't have ABS nor ESP because some DTC errors (U3002:62-48 for PSCM and U3002:62-48 for ABS modules). Will this do the trick?
