Code 2015 Mondeo 2.0 TDCi injectors
Andympeck
Vehicle: 2015 Mondeo 2.0 tdci2
Post by Andympeck » Wed Mar 20, 2019 11:53 pm
I have a 2015 Mondeo 2.0 TDCi in for repair. It needs a new injector. It has Delphi injectors.
Will Forscan code the injector, as I can not find an option to do this. Only to "reset learned values"
Thankyou in advance.
RYM6746
Vehicle: Fiesta petrol 1.2 60Kw 2010
Re: Code 2015 Mondeo 2.0 TDCi injectors
Post by RYM6746 » Sat Mar 23, 2019 1:39 am
Probably means you don't need to code them. Just reset learned values and the ECU will do the rest. Take it on a long drive afterwards and the ECU will teach itself the parameters of the injectors. Just make sure you go through all the gears and through the full rev range. Making sure the engine is cold when you start and hot when you finish
sappo
Vehicle: FORD MONDEO MKIII TDCI 115CV B4Y
Post by sappo » Mon Mar 25, 2019 10:30 am
It will work in the same way for Mondeo MKIII from 2002? I mean, the Ecu will learn the new injector parameters? Is there any posibility to update the parameters through the OBDII+FORScan?
Thank you in advance
sappo
Post by sappo » Mon Mar 25, 2019 10:31 am
