2008 -2011 F350 spreadsheet
Posted: Fri Mar 15, 2019 3:42 pm
by curtisgriffin
I have a 2009 F350. I see a link for a spreadsheet for an F250. Would F250 and F350 be the same speadsheet? I would think not but I have searched for F350 and found nothing. Also I am assuming years 2008 - 2011. Anyone know how to get the correct spreadsheet for my vehicle?
Re: 2008 -2011 F350 spreadsheet
Posted: Fri Mar 15, 2019 4:37 pm
by gg1234635
alot of the settings are the same across all of ford range. Make sure you do a backup first before making a change and then try the 250 code. if it doesnt work but your backup back in.
Posted: Sat Mar 16, 2019 4:11 pm
by curtisgriffin
I'll try that. Thanks
Posted: Wed Jul 17, 2019 3:36 am
by GMIJackso
Mind sharing which OBD adapter you found that is compatible? I have a 2011 F350 and can't find one that lists the F350 as compatible as it's no longer a "light truck", stopping at the 250s. I looked around the forums and see all of the "choosing an adapter" things, but I'd prefer to get one that someone else confirms is working on the "same" vehicle. Thanks!
