how to release the automatic closing of the side mirrors. kuga 2017
epry
Vehicle: kuka 2,0tdci 150cv 2018
Post by epry » Wed Mar 13, 2019 6:12 pm
hi I would like to know if it is possible to automatically unlock the side mirrors using ford scan?
every time you close the car they close automatically, but in case of heavy snowfall I have to pay attention to clean them carefully before opening the car, so to avoid this I would like to disable the automatic function and decide whether to close them by pressing the button. or not.
is it possible to do it with fordscan? is where should I change?
sorry if my english is from 0
Nutloose
Vehicle: BMW E36 V6 Project
Re: how to release the automatic closing of the side mirrors. kuga 2017
Post by Nutloose » Wed Mar 13, 2019 9:12 pm
I Came across this problem on a Focus and there was no configuration options with IDS to disable the function.(CCF not editable field)
We ended up interupting the power to the folding motors and switched their function manually.
It needs to be done to prevent damage when the mirror is frozen solid.
It may be that you could downgrade the BCM by modifying the As-Built data and re-programming
good luck
gg1234635
Post by gg1234635 » Wed Mar 13, 2019 10:29 pm
Do you not have a manual over ride along side your window openers on the drivers door? All you do is disable autofold/unfold and just do it manuall from the door panel?
epry
Post by epry » Fri Sep 27, 2019 7:24 pm
ok guys but i'd like to figure out where to get this cable out of the way.
if someone is more precise in the description to tell where the cable is and what color it is I can put a manual switch where to enable is disable the automatic closure
mictei
Vehicle: KUGA 2017 179HP 2.0TDCI
Post by mictei » Mon Sep 30, 2019 7:53 pm
- Ignition on
- Retract mirrors at the push of a button
- unfold the mirrors by hand
- Switch off the ignition again
- they are already deactivated
  Activate everything in reverse.
epry
Post by epry » Fri Dec 20, 2019 8:27 am
not found
epry
Post by epry » Fri Dec 20, 2019 8:28 am
- Ignition on
I tried as he told me.
- I started the car
- closed the mirror by electronic key
- I turned off the car
- result the mirror does not open manually, I forced it is flexed, if I insist I am sure that I break it
