Turn Signal Flash Count 2019 USA Ranger
RCMUSTANG
Vehicle: 2017 Fusion Sport
Post by RCMUSTANG » Fri Mar 08, 2019 4:16 am
I have a 2019 USA Ranger and I've tried to make the changes based on the spreadsheets available in both the F150 and Fusion. None of the changes worked. It still flashes 3 times.
Automatic Turn Signal Flash Count
724-01-01 (2014+ MY) xxxx xXxx xx
(SCCM)
0 (One Flash)
4 (Two Flashes)
6 (Three Flashes - Default)
8 (Four Flashes)
A (Five Flashes)
C (Six Flashes)
E (Seven Flashes)
martynm
Vehicle: Everest 2.2 Diesel 2018
Re: Number of Flash Issue
Post by martynm » Sun Mar 10, 2019 2:28 pm
Worked for me on a 2018 South African Everest, changed to 5 flashes
RCMUSTANG
Post by RCMUSTANG » Sat Apr 06, 2019 4:10 pm
I'm told by another Ranger forum there is a ton more coding on the U.S. Ranger they've never seen before. It didn't work for us.
RCMUSTANG
Post by RCMUSTANG » Wed May 15, 2019 2:26 am
Anyone have any luck with this?
RCMUSTANG
Re: Turn Signal Flash Count 2019 USA Ranger
Post by RCMUSTANG » Wed Nov 13, 2019 4:36 am
Bump. Anyone make any head way on this? Also, when you enable climate in the productivity screen it appears, you can adjust temp and fan speed but goes back to the setting from Sync or hard buttons. In other words does not affect the controls.
