Focus Mk3.5 Auto - Sport Mode Stop Start Enable
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Post by davetcollection » Thu Feb 28, 2019 12:17 pm
We have a Focus ST-Line 1.0 Auto and would like to activate auto start/stop when in "Sport" mode on the gear shift.
It works fine when in "D".
Would anybody have any codes for the PCM?
Many Thanks in advance
Andyfocus
Re: Focus Mk3.5 Auto - Sport Mode Stop Start Enable
Post by Andyfocus » Fri Mar 01, 2019 4:33 am
auto stop start in sports mode is probably a software coding as its in sport mode so it doesnt stop when ur at the line , so doubt it will be available to change other than hacking the software going threw thousands of lines of code and finding it , then you would get an u1900 code for incorrect setting , which you would then need to do the same again to disable that . i could be wrong but i would think that ford would think some one who wants sports mode wouldnt want the stop start to ever kick in .
