ECU delphi map change 140-163 ?
adixx87
Vehicle: ford galaxy 2.0tdci 140ps PS 2014
Post by adixx87 » Sat Feb 23, 2019 8:10 pm
Hi.
Is there an option to switch the map in delphi ECU for 2.0 dw10c engine using the Forscan ?
Andyfocus
Re: ECU delphi map change 140-163 ?
Post by Andyfocus » Sat Feb 23, 2019 10:08 pm
forscan does not currently support software changes updates.
can only do as built data , or change values in the data / central config .
daktona
Vehicle: Ford Mondeo, FMBA, 2.0TDCI, 131hp, 2002
Post by daktona » Fri Aug 09, 2019 7:14 am
Actually the software for the 163 hp is in the BCM. You need to change from 140/320 to the 150/350. Not sure about the 300 figures from my mind, but they are the only ones. You need to change this in IPC and BCM and then reset both modules.
