Activate ACC on Ford Galaxy 2017
xpmaster
Vehicle: mazda 6 121hp 2005
Post by xpmaster » Wed Feb 20, 2019 2:47 pm
Is it possible to activate the adaptive Cruise Control on a 2017 Ford Galaxy with Forscan or do i Need UCDS ?
Neorej
Vehicle: S-Max 2016 2.0 EcoBoost 240Pk
Re: Activate ACC on Ford Galaxy 2017
Post by Neorej » Wed May 15, 2019 10:57 am
I have a 2016 Ford S-Max and im also looking for this information.
Mine has Collision alert and detection and "normal" Cruise control including lane-keep assist.
So i guess all the hardware for Adaptive cruise control should be there.
Ofcourse the buttons on the steeringwheel won't match but that should not be the problem.
I have checked some forum and other internet sources and noticed a few "codes" that are related to ACC but i'm not sure what to set to what.
If there is somebody with a Ford that actually has ACC (preferable a S-Max or Galaxy, but probably a Mondeo from the same year might also work)
Please share the following values for the following codes using Forscan.
And share what options you have, especially things like cruise control, lane assist, brake assist, collision detection etc.
BCM 726-13-01
IPC 720-01-01
IPC 720-01-02
SCCM 724-03-01
ABS 760-03-01
rathje
Vehicle: S-MAX PS 180 2017
Post by rathje » Wed Jun 19, 2019 6:11 am
Did you ever figure out the coding for activating ACC (Adaptive Cruise Control) ?
Thanks in advance.
//Rathje
BCM 726-13-01
IPC 720-01-01
IPC 720-01-02
SCCM 724-03-01
ABS 760-03-01
CatHerder
Vehicle: Ranger 3.2TD 2019
Post by CatHerder » Thu Jun 20, 2019 12:20 pm
Not an S-Max or Galaxy... an Australian Ranger. It has the full suite of adaptive cruise control, lane assist, brake assist, collision detection, speed sign recognition.
BCM 726-13-01
;Block 13
7261301810C60490077
72613020042
IPC 720-01-01
IPC 720-01-02
;Block 1
72001012F4E14006822
720010223C29AA9
SCCM 724-03-01
;Block 3
72403012114000064
ABS 760-03-01
;Block 3
7600301001984
rathje
Post by rathje » Thu Jun 20, 2019 12:24 pm
Thanks for your reply. Are your's a diesel or a petrol engine?
Also.. Any chance you have the value in none HEX ? :roll: :lol:
BCM 726-13-01
;Block 13
7261301810C60490077
72613020042
IPC 720-01-01
IPC 720-01-02
;Block 1
72001012F4E14006822
720010223C29AA9
SCCM 724-03-01
;Block 3
72403012114000064
ABS 760-03-01
;Block 3
7600301001984
CatHerder
Post by CatHerder » Fri Jun 21, 2019 8:58 am
Diesel engine.
rathje
Post by rathje » Fri Jun 21, 2019 9:21 am
Nice. I have heard rumors that it was only possible on petrols.
Any chance you can help convert the HEX codes ?
Thanks.
Diesel engine.
papinist
Vehicle: 2015 Ford Mustang EcoBoost Euro
Post by papinist » Fri Jun 21, 2019 9:35 am
Im interested in this, too.
I have a 2017 Edge Sport, Euro model so diesel engine. The euro variant has all other stuff included (brake assistant, pre-collision assist, traffic sign recognition and standard cruise control).
I believe that, after changing as-built codes, we need to replace the standard CC steering wheel buttons with the ACC dedicated ones.
rathje
Post by rathje » Fri Jun 21, 2019 9:40 am
I have the same in my s-max, and just added the new ACC steering wheel button.
The only thing left for me should be the cooding. :)
I've got the part number for the button if you need it?
papinist
Post by papinist » Fri Jun 21, 2019 10:25 am
The part number would be great :D Where have you found the part? Ebay? or some other seller?
