Disable TMPS Mazda 6 GJ 2013
AR1
Vehicle: Mazda 6 GJ 2013
Post by AR1 » Mon Feb 04, 2019 8:01 am
Hello, gentlemen, know you how can I disable TMPS for Mazda 6 GJ 2013? I mean permanent shutdown, I do not mean reset with button on dashboard.
I searched for Google and found the procedures for Ford, but they do not work for Mazda. I have not sensors in tires. TMPS working from ABS. I do not have a check on the on-board control computer for tires (maintenance schedule) , it's turned off.
THX
Andyfocus
Re: Disable TMPS Mazda 6 GJ 2013
Post by Andyfocus » Mon Feb 04, 2019 3:49 pm
as far as i know if you dont have sensors you dotn have TPMS , thier is no way the abs sensors can read the tire pressure with out the sensors even if it did do that which it doesnt .
AR1
Post by AR1 » Mon Feb 04, 2019 4:14 pm
You're wrong. There are two ways TMPS - sensors that read from tire pressures, and the other is an ABS system that scans and compares wheel speeds.
I'm sorry but I'm going to ask you to keep the topic.
AR1
Post by AR1 » Wed Feb 06, 2019 12:56 pm
Resolved, the system is disabled by coding.
m4f1050
Vehicle: 2019 Ford F150 4x4 Lariat
Post by m4f1050 » Mon Jun 24, 2019 1:14 pm
Hi, can you help me with the TMPS coding? Where do I change it to disable it?
Thanks!
