Ford Ecosport 2018-2019 ( 2018 MY) - how to activate DRL
erick3.14
Vehicle: Ford Ecosport TiVCT 1.5L 2019
Post by erick3.14 » Sun Feb 03, 2019 8:28 pm
sorry for this post. I checked search first and found only 24 pages with reference for Ecosport, but I could not find anything related to DRL.
In fact I found this post but I saw it is quite old and no progress at all:
viewtopic.php?f=16&t=4699&p=16840&hilit=ecosport#p16840
My Ford Ecosport is a 2018/2019 model. It is the entry level model in Brazil : Ford EcoSport TiVCT 1.5L 2019 ( 2018 MY ).
It originally comes with the regular bulb headlights and I swapped for the xenon+projector headlights version which has also DRL led built-in. It is a direct and plug and play replacement.
It is working fine, but I´d like to have LED DRL turned on as soon as ignition is on. I can only have led DRL turned on if I change the light switch for the parking light condition. And I don´t like to to turn it on and off every time I drive . I would like to have the proper DRL setup .
I check and tried different settings from the helpful links area (viewtopic.php?f=16&t=4393) , but I was not successfull so far .
I could activate some other features, specifically for Sync3, but the headlight DRL I could not find the proper settings so far.
Some examples of what I tried, but didn´t work at all
726-11-01 001B-001B-0075 -> 011B-001B-0075
726-26-02 0000-0000-0055 -> 0100-0000-0055
Another interesting thing I noticed, is that my Ecosport only shows following address range
BCM 726-01-01 up to 726-26-05
APIM 7D0-01-01 up to 7D0-08-02
And some of the helpful links and guides make reference for higher address range that I can´t access.
Can anyone help me? Does anyone know if there is any specific settings for the proper DRL operation in the Ecosport?
aarueira
Vehicle: Ecosport 2019 SE 1.5 AT
Re: Ford Ecosport 2018-2019 ( 2018 MY) - how to activate DRL
Post by aarueira » Mon Apr 01, 2019 4:51 pm
Oi Erick, boa tarde, você descobriu alguma coisa? Estou buscando este código também, além do código para ativação da camera de ré.
Hi Erick, have you found anything? I'm also looking for this code and also for the backup camera code. Thx
erick3.14
Post by erick3.14 » Tue Jul 16, 2019 3:35 am
Reverse camera activation in Ecosport is simple. It is same as other Ford cases reported here in the group. I can get it in my computer later and share with you the details
aarueira
Post by aarueira » Thu Jul 18, 2019 5:54 pm
Ok obrigado. Aguardo envio. Pode ser por email: aarueira@gmail.com
erick3.14
Post by erick3.14 » Mon Jul 22, 2019 9:16 pm
For Reverse Camera activation in Ecosport
SYNC3
REVERSE CAM
RearView camera 7D0-01-01 xXxx xxxx xxxx
0=disabled
2=enabled (default)
A= enabled with obstacle detection
A= obstacle detection did NOT work on my Flex . need someone to confirm if it works or not
In my case I changed mine x0xx xxx xxxx to x2xx xxxx xxxx:
206A 0006 0069 -> 226A 0006 006B
consp
Vehicle: Fiesta 125hp 2017 (My13.25 Mk7.5, With EU Sync3)
Post by consp » Tue Jul 23, 2019 9:21 am
SYNC3
REVERSE CAM
0=disabled
2=enabled (default)
For PDC (obstacle detection) you also need to alter 7D0-04-02 xxx* and have PDC installed:
0=no PDC/PSM/SAPP
1=rear PDC
2=rear/front PDC
3=rear/front PDC/SAPP (NA HMI)
4=rear/SAPP (EU HMI)
5=rear/front PDC/SAPP (EU HMI)
6=rear/SAPP (EU HMI)
7=rear/front PDC with APA
8=APA Lite
9=APA Lite Plus (SAPP/POA-10 channel)
erick3.14
Post by erick3.14 » Tue Jul 23, 2019 4:34 pm
Latest Forscan release enabled more features and coverage for Ecosport.
Not sure if it may help or not:
Vehicle:
Model: Ford EcoSport
Engine: TiVCT
Capacity: 1.5L
Year: 2019
Generation: 2018 MY
Fuel: Gasoline
Transmission gear: Automatic
PCM - Powertrain Control Module
Part number: GN15-12A650-DTC
Strategy : GN15-14C204-DTC
Hardware type: JX6A-12B684-BHA
Total Distance: 7140.0 km
APIM - Accessory Protocol Interface Module
Part number: JN1T-14G371-BBC
Strategy : GB5T-14G374-DG
Calibration: GB5T-14G375-BB
BdyCM - Body Control Module
Part number: HU5T-14B476-FCH
Strategy : HU5T-14C184-ACK
ABS - Antilock braking system
Part number: GN15-2C219-AD (latest known: GN15-2C219-AF)
Strategy : GN15-2D053-CC
PDM - Passengers Door Control Unit
Part number: GN15-14B533-AG
Strategy : GN15-14C108-AG
DDM - Drivers Door Module
Part number: GN15-14B531-AG
Strategy : GN15-14C064-AG
RCM - Restraint Control Module
Part number: GN15-14B321-BJ
Strategy : GN15-14C028-CA
Calibration: GN15-14C098-BJ
HVAC - Heating Ventilation Air Conditioning
Part number: GN15-19980-AJ
Strategy : H1BT-14C178-AJ
PSCM - Power Steering Control Module
Part number: GN15-3C579-AG
Strategy : GN15-14C217-AG
ACM - Audio Control Module
Part number: J3BT-18C815-FM
Strategy : H1BT-14C044-GM
Calibration: J3BT-14C045-FE
SCCM - Steering Column Control Module
Part number: GN15-3F944-AH
Strategy : GN15-14C579-AH
IPC - Instrument Panel Control Module
Part number: GN15-10849-AAH
Strategy : GN15-14C026-AAG
Calibration: GN15-14C088-AAD
GWM - Gateway Module A
Part number: H1BT-14F642-CE
Strategy : H1BT-14F530-AE
Any ideas on how to enable DRL for Ecosport?
ksoulis
Vehicle: Ford Ecosport, 1,5 TDi-100 ps, 2018
Post by ksoulis » Wed Sep 04, 2019 1:23 pm
You can do limited changes from IPC Module Comfiguration and BCM.
I've managed to use fog lights as DRL through this process.
Pamporovo 006 (3).JPG (202.8 KiB) Viewed 1905 times
matias316
Vehicle: Fiesta, 1.6 Sigma TiVct, 120hp, 2016
Post by matias316 » Sun Sep 29, 2019 8:09 pm
When you did that change in IPC related to DRL, stop working as a DRL as soon the ignition is on??
I enable the option you show and the DRL stop working.
Which aditional changes we have to do in BCM in order to make it work again?
Mine is EcoSport MY 2018 Argentina.
Thanks.
carlitoos
Vehicle: Ecosport,1.5 dragon at 2019
Post by carlitoos » Wed Jan 01, 2020 7:57 pm
SYNC3
REVERSE CAM
0=disabled
2=enabled (default)
Boa tarde Erick
Tenho uma ecosport se 19/20 e coloquei um volante com cruze control, preciso ativar no forscan e também o fechamento global dos vidros, mas pesquisei e não encontrei nada a respeito para o nosso modelo de ecosport, você tem alguma planilha, ou consegue me ajudar com qual códigos preciso trocar? se puder me ajudar com alguma coisa eu ficarei muito grato!
