Focus 4 DRL
Axe123
Vehicle: Mondeo MK5
Focus 4 DRL
Post by Axe123 » Mon Jan 28, 2019 4:13 pm
Does enybody knows which bit has to be changed in BCM to disable the DRL?
Andyfocus
Re: Focus 4 DRL
Post by Andyfocus » Mon Jan 28, 2019 8:46 pm
try the IPC ;)
and change the top to eningeering mode to show hidden options .
theirs also another thread somewhere i just read with a couple of people tring to do the same thing could be worth looking their (it shows the options etc ) , and joining in .
Axe123
Vehicle: Mondeo MK5
Re: Focus 4 DRL
Post by Axe123 » Tue Jan 29, 2019 5:51 am
You mean I have to change something in IPC via forscan?
Andyfocus
Re: Focus 4 DRL
Post by Andyfocus » Tue Jan 29, 2019 8:44 am
should be able to change it in the ipc or bcm , ipc should have the options your looking for when you change the top left option to show engeering mode and hidden options , scroll down the list change the one u want write to module then do a reset to take effect .
Axe123
Vehicle: Mondeo MK5
Re: Focus 4 DRL
Post by Axe123 » Tue Jan 29, 2019 9:29 am
What do you mean by top left option? I try to write changes in IPC, it's starts to write until 15%, than it says serrvice procedure interrupt.
Andyfocus
Re: Focus 4 DRL
Post by Andyfocus » Tue Jan 29, 2019 11:06 am
u dont need to change any lines manually they are option in engeering mode to adjust it to what you want .
Axe123
Vehicle: Mondeo MK5
Re: Focus 4 DRL
Post by Axe123 » Thu Feb 07, 2019 9:22 am
The problem is that IPC can not be writed with Forscan 2.3.19.
I think I have to wait for new version of FScan.
Andyfocus
Re: Focus 4 DRL
Post by Andyfocus » Thu Feb 07, 2019 10:34 pm
yes seems lots are having problems at the moment with writing to modules , you could try an older version but success seems limit with that as well ,
jon.willis@usa.net
Vehicle: 2012 Ford Focus
Re: Focus 4 DRL
Post by jon.willis@usa.net » Wed Apr 24, 2019 2:05 am
Yes, change to witch mod?? None work as far as I can tell?? 2012 Focus Titanium...
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Re: Focus 4 DRL
Post by davetcollection » Thu Apr 25, 2019 1:55 pm
2.3.20 allows you to select DRL on/off option in the IPC,
You then go into cluster menu and can tick DRL on or off
