Replacing 2012 f150 BCM and PCM
Trekboer
Vehicle: 2012 F150 5.0 Crew Lariat
Post by Trekboer » Fri Dec 14, 2018 9:46 am
I have a 2012 F150 that needed BCM and PCM replaced. Neither we're comunicaring. Both modules have been installed in vehicle and now comunicate with Forscan. I am trying to determine proper procedure order for reprogramming the modules. For instance which should be done first so others can talk to it... "PATS key programing", "Loading as built data", "Module Initialization" Etc...?
