2015 Ford F-150 Radio muted when seatbelt not buckled-mykey
spoitra
Vehicle: 2015 Ford F 150 5L V8 appr. 360HP
Post by spoitra » Sat Dec 01, 2018 5:59 pm
I have a Ford F-150 and I activated the mykey without an extra key to deactivate it. The only thing I want to know if there is a way to change it so that when I’m not buckled in it doesn’t mute my radio?
twisterrescue
Vehicle: 2003escapeltd
Re: 2015 Ford F-150 Radio muted when seatbelt not buckled-mykey
Post by twisterrescue » Tue Dec 04, 2018 3:04 am
YER SCREWED .you need an adm. key to delete MY KEY .and more bad news . that flip key cost 195.00 at a ford dealer and requires .1 hour labor min charge to program spare key TWO KEYS ARE REQUIRED TO PROGRAM KEYS NO FLIP KEYS CAN BE PROGRAMED WITH FORScan! . approx.120.00 more just under 350.00 .at the ford dealer I am part of .it also limits top speed . you could PRAY that in the IPCM module the MY KEY option is shown to enable or disable GOOD LUCK!!!!!!!!!!!!
soobilly
Vehicle: ford f-150 2.7 2016
Post by soobilly » Thu Dec 06, 2018 1:03 pm
IPC 720-02-01 -**** *x** **** X=0,1,2,3 all disable my key
ccdowns
Vehicle: Ford Fusion, IVCT, 2.5L, 2013
Post by ccdowns » Sun Dec 23, 2018 3:19 am
<r><QUOTE author="soobilly" post_id="27239" time="1544101394" user_id="136083"><s>
</s>
<e>
</e></QUOTE>
Thank you! This worked perfectly to disable MyKey!</r>
Noscopy
Vehicle: F-150, gasoline, 3.5L ecoboost, 370hp, 2015
Post by Noscopy » Mon Dec 24, 2018 4:00 am
way to go !
pdejda
Vehicle: Fiesta/MK7/125
Post by pdejda » Thu Apr 18, 2019 3:08 pm
Ok! In my Fiesta 2016, I just see in IPC 720-02-01 -> 012B. Maybe I looking bad? Does it just look different in this model? :roll:
rawcookiedough
Vehicle: F150, 5.0, 2014
Post by rawcookiedough » Wed Apr 24, 2019 11:02 am
Will this work on a 2014 f150?
