Adding remote start to 2011 Fusion
1wild-horse
Vehicle: F-150 yote 2017
Post by 1wild-horse » Sun Nov 25, 2018 8:57 pm
Hey guys,
Anyone know what to change in a 2011 Fusion to turn on the remote start when installing the Ford accessory kit?
Much appreciated
twisterrescue
Vehicle: 2003escapeltd
Re: Adding remote start to 2011 Fusion
Post by twisterrescue » Tue Nov 27, 2018 6:21 am
IF IT is the (old) kit wired to ign switch .t harness . forscan will not help .only the new 2013-2019 fusion .uses a gateway module .that requires .IDS or FORSCan .to enable remote start .If it is the ford kit from ford .DIAL 1800 ford key ford accessory tech support .good luck I hated those kits!
1wild-horse
Post by 1wild-horse » Wed Nov 28, 2018 2:00 am
Thanks for the heads up. Never thought of the gateway module thing. I've put several of those kits in, they are not bad. Have to activate with IDS, which is a bit of a problem now that I don't have 1st hand access. Too bad Forscan can't configure for it.
twisterrescue
Post by twisterrescue » Thu Nov 29, 2018 6:34 am
FORScan can enable all remote start options .on newer stuff as long as car has hood switch .start car close all doors pull hood release .should show hood open in cluster!if not a new hood latch assy.and wiring to proper bcm .input is required
SHUCKER1
Vehicle: 2015 F-250 Super Duty
Post by SHUCKER1 » Sat Dec 15, 2018 10:01 pm
Has anyone figured out what to change to activate this function?
I do have the hood switch.
Chris
Regards,
Chris
1wild-horse
Post by 1wild-horse » Fri Dec 28, 2018 7:52 pm
Just a quick update. 2011 Was old enough I didn't need a scan tool to program. If you installed a Ford genuine accessory kit, you just need to select options in the programming bank, then program two pats keys to the security bypass by cycling them in the ignition after exiting the program bank.
Ahmed_88_alsaffar
Vehicle: focus,2.0L,160hp,2017
Post by Ahmed_88_alsaffar » Thu Jun 06, 2019 11:50 am
Hello.
I have a Ford Focus 2017. I'm adding a hood ajar sensor in order to use the remote start function. I have installed the sensor in place, but I can't find where to connect the two wires of the sensor!
What connector (in BCM) and what pins are used to connect the hood ajar sensor?
and what connector in BCM and what pins for the fog lights (left and right and n?
twisterrescue
Post by twisterrescue » Sat Jun 08, 2019 2:02 am
bcm connector (2280c) pin#14 blue orange needs to show ground w/hood closed .for remote start . as for fog lamps (c2280B) left side pin 12 brown. right side pin 5 yellow orange . plus headlamp switch needs changed .and programming to ipcm for fog indicator to work like factory
