Enabling autolock on Ford Fiesta 2010
BenWelsh1996
Vehicle: Ford Fiesta Zetec S 1.6 litre 95PS 2010
Post by BenWelsh1996 »
hey all!
Tried to activate the auto door lock feature on my car, went onto the configuration mode and found the option to enable the auto lock, i activated it on the CC and the BCM, I activated it on both modules, the car acknowledged the change.
now when i went to test this new feature by driving over 10-20 mph the doors didnt lock, even though they was set to lock?!
Any help would be amazing!
thanks!
Yoko89
Vehicle: Fiesta 1.6 105hp 2014
Re: Enabling autolock on Ford Fiesta 2010
Post by Yoko89 »
Put the key in the ignition and turn it to on.
Press the Unlock button three times.
Turn the ignition off.
Press the Unlock button three more times.
Turn the ignition back to on.
The horn should beep once. This tells you that you’re now in programming mode.
Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you’re reactivating the system.
Turn the ignition back to off and listen for the horn to beep one time confirming that the programming was accepted.
