2013 ford escape back up camera
jrye22
Vehicle: Ford Escape 2.0L 2013
Post by jrye22 » Wed Nov 21, 2018 1:53 am
hello all i have my APIM open on FORscan and am trying to enable the back up camera for my 2013 escape but i cant seem to locate the correct codes from my understanding i have to change a value in 7D0-01-01 but i dont know the number any help please
12voltWILL
Vehicle: F150, 5.0L v8/285HP, 2015
Re: 2013 ford escape back up camera
Post by 12voltWILL » Fri Nov 30, 2018 12:17 am
What size screen?
jrye22
Post by jrye22 » Fri Nov 30, 2018 12:33 am
It’s the 8inch but I think I figured it out just waiting on a cable
Jayson T
Vehicle: Ford Escape ecoboost turbocharged 2.0 2013
Post by Jayson T » Fri Dec 14, 2018 8:32 pm
Hi. i´ve configured several vehicles using Forscan. To activate your back up camera in Sync 2 you should set your APIM with this code:
7D0-01-01 x3xx x1xx xxxx
I tested that configuration in diferent Ford Fiesta using Sync 2, but it is the same APIM module, so it have to work.
Jayson T
Post by Jayson T » Fri Dec 14, 2018 8:54 pm
with this codes you get your back up camera to work. if you do not have yor camera connected, you can program your APIM, put your car in Reverse shift and wait for a few seconds until your display shows someting similar to "camera not detected. Direct to your dealer". That means the car is correctly programed, and then you can use any back up camera, not only Ford cameras. Obvioulsy you need a video connector behind the display to connect your cam; you can buy an adapter or make connections by your own (i prefer an adapter).
jrye22
Post by jrye22 » Fri Dec 14, 2018 11:00 pm
I have installed everything and it works thanks for the help
kevs74nova
Vehicle: 2013 Ford Escape 2.0L Ecoboost
Post by kevs74nova » Sat Mar 23, 2019 1:33 am
did you end up using an OEM or aftermarket camera? I enabled the APIM feature, and that seems to be ok. But it doesn't seem that my 2013 Escape SEL was pre-wired in the rear hatch. I can't find a harness for the OEM camera.
jrye22
Post by jrye22 » Sat Mar 23, 2019 2:18 am
I used an aftermarket camera from amazon and a wiring harness from there as well
This is the harness:
OCSTAR 54 Pin Apim Connector Sync 1 Ford Camera Input Harness Cable Extension on SYNC 2 or SYNC 3 with RCA Connector for Camera 35cm 14 inches
This is the camera:
NOAUKA Waterproof IP68 Night Vision 170 Degree Car Rear View/Reversing/Reverse Camera Universal Color CMOS Imaging Chip Backup Parking HD Front View Camera
I ran power to the camera from a T tap into the reverse light and grounded near there as well hooked all the wires and ran forward once the dash is apart the harness connects into the factory one and then you just plug in your video connector if I remember correctly I have since sold the escape and went with a 19 ranger
john51
Vehicle: Ford S Max 2017 Diesel 2.0 150 bhp
Post by john51 » Fri Jun 07, 2019 3:40 pm
Hi There!
I have a Brit S Max and was going along the same lines. No harness connectors either for the camera or image processor, I have been told the harnesses suit the build spec only and retro fit isn't catered for.
I am going to use a T harness of Amazon and a small camera and then program hopefully.
Best, John.
john51
Post by john51 » Sun Jun 09, 2019 10:56 am
A good result!
I used the non "As Built" option and managed ( I cant remember how!) to get to the enable/disable options, and simply selected enabled and saved the changes.
I now have a blue screen in reverse because I haven't fitted the camera yet, and a reduced vehicle PDC image which works as before. :) :D
Just the installation to do now. This has saved loads, kits for retrofit DIY are near the £300 mark with a programmer dongle.
I think my total outlay with the camera, T Harness, and a trim remover kit from Amazon is about £55.00. :)
I have a screenshot of the re-written APIM As Built if anybody is interested, it may not suit US models.
