2016 F250 results
insectguy
Vehicle: Ford F-250 lariat, gas 6.2l, 2016
2016 F250 results
Post by insectguy » Sat Nov 17, 2018 8:21 pm
Today was the first time I've used FORScan. Wow! What a neat program! Here's everything I did:
Bambi mode – haven’t checked it out yet, but will tonight when it gets dark
Belt Minder – removed the seat belt reminder dinging
Daytime Running Lights – turned on the fog lights for DRLs. Could have used the turn signals or 50% headlights.
Active Noise Control (Fake engine noises) – it was already turned off 😊
Navigation override – now the passenger (or driver) can make changes to the navigation while the vehicle is moving
Turn signals – increased the momentary turn signals to 5 blinks from 3
Global window control was already enabled
Remote start duration was already at 15 minutes
I couldn’t get the codes for the automatic mirror folding, the driver mirror lowering when in reverse, or the temperature values to appear above the gauges. The F150 chart has them listed, but they modules don’t appear in the superduty menu (at least the menu I have).
Any thoughts or code shares on these items?
dkeyt7
Vehicle: Ford F-250, 6.7L Diesel, 2015
Re: 2016 F250 results
Post by dkeyt7 » Tue Dec 11, 2018 1:46 pm
Did you ever check out the bambi mode? Wondering if the f150 sheet works for the f250?
DrChills
Vehicle: 2011 Ford F350 6.7L
Post by DrChills » Wed Jan 23, 2019 3:17 pm
Use this document, a lot of people put a massive amount of time trying the F150 changes on the SD's. I have found the ones that I want. Bambi mode works great.
https://docs.google.com/spreadsheets/d/ ... I/htmlview#
CrewmanRedshirt
Vehicle: F250, 6.7 Diesel, 2016
Post by CrewmanRedshirt » Tue Jul 16, 2019 9:13 pm
How did you disable the Belt Minder? I do not see it listed in the 2016 F250 Speadsheets.
Also, has anyone gotten the Lincoln Mirrors mod to work on a 2016 F250? I believe I've seen it done on the 2017 F250, but I can not find any information for the 2016 F250.
Thanks.
