Ford Escape Hex Value Chart?
twiggs462
Vehicle: 2014 Ford Escape
Post by twiggs462 » Fri Nov 02, 2018 4:06 am
Does anyone have a sheet that covers all of the module Hex Codes? I am curious to see all the items I can edit and what the values that need changed are. I can probably answer a lot of my own questions if one of these are out there. I seen on YouTube people had some for F150s and other related vehicles.
Thanks for any feedback you might have.
choppermike
Vehicle: 2013 Escape, 2013 F150
Re: Ford Escape Hex Value Chart?
Post by choppermike » Wed Dec 05, 2018 3:39 am
I have a 2013 Escape, and would like a spreadsheet for it also if someone has one or common value changes.
billybassman21`
Vehicle: ford escape v6 3.0 2012
Post by billybassman21` » Sun Dec 16, 2018 3:22 am
I see lots of people asking for this, but no one ever replies. Does it not exist and why? I would really like to find a hex chart for my 2012 Escape.
Don Ridley
Vehicle: 2016 Transit Connect
Post by Don Ridley » Mon Dec 17, 2018 4:58 pm
Ford Escape uses central configuration (CC) instead of manually changing hex codes. Do a quick search on this site and check out some Escape forums. CC is also used by the Focus.
WuNgUn
Vehicle: 2019 Escape Titanium
Post by WuNgUn » Fri Nov 01, 2019 4:53 pm
That doesn't mean you can't also edit hex values for other modules!
Don Ridley
Post by Don Ridley » Sat Nov 02, 2019 3:34 am
Yes and no. Simple changes to IPC or ACM etc can be made. Search other forums for escape and focus for more info. But complicated changes like cruise control, LED headlights etc must be done through CC.
The spreadsheets that exist are the work of some dedicated enthusiasts that meticulously checked and tested each function.
WuNgUn
Post by WuNgUn » Sun Nov 03, 2019 4:48 pm
My 2019 doesn't list a IPC module :(
