2012 Fusion - Bambi Mode Question
dmoral1
Vehicle: Escape, 2.5L, 2013
Post by dmoral1 » Sat Oct 27, 2018 12:45 am
Has anyone seen or have the as-built data Mod for a 2012 Fusion? See the attached snapshot on the as-built for my 2012 Fusion if anyone has an idea where to make the change.
GEM_SJB Module Configuration (As-Built Format).png (735.88 KiB) Viewed 766 times
wuzek68
Vehicle: Fusion Titanium , 2.0 turbo , 2016
Re: 2012 Fusion - Bambi Mode Question
Post by wuzek68 » Sat Oct 27, 2018 5:11 pm
Not sure on 2013 HB and Fogs enabled 726-38-01 xxxx xxx0 xxxx or 2014+ 726-27-01 xxxx xxx0 xxxx HD + Fogs enabled
dmoral1
Post by dmoral1 » Sat Oct 27, 2018 9:39 pm
Thanks for the codes, however the codes end at 726-24-*** with my 2012 Fusion and no other higher numbers are available or detected. That's why I'm asking if anyone has ever seen any for this Model Year. Also, the as-built Modules appear to be in the BdyCM (BCM) for most of those vehicles that can be modified compared to the GEM/SJB Module for my vehicle. I figured I would ask anyway, but it may not be possible with my specific vehicle. Unless someone knows a different trick to modify.
Again, Thanks
