Ford Kuga - Enable Reversing Camera
Kugaman
Vehicle: Kuga Titainium 180 Auto
Post by Kugaman » Fri Oct 19, 2018 6:54 pm
Hi All,
For days now I have been searching the internet looking for the code to change in Forscan to enable in my Sync 2 system a third part reversing camera. For love nor money I cant find it. Before starting the project I thought I had this code but somehow have miss placed this information.
Not sure if the year of the car make any difference, but its Ford Kuga 65 Plate and Sync2 system
Please, please can anyone help me ;) . Thank you
Simon
semiho
Vehicle: Focus Mk4 St-Line Ecoblue A/T
Re: Ford Kuga - Enable Reversing Camera
Post by semiho » Fri Oct 19, 2018 9:44 pm
7D0-01-01 x*xx xxxx xxxx
set * to
3: With Camera No PDC (parking distance control)
9: No camera with PDC
B: With Camera with PDC
Kugaman
Post by Kugaman » Fri Oct 19, 2018 11:19 pm
Thank you so so much I am so appreciative, what section of forscan is the code “wrench” etc
semiho
Post by semiho » Sat Oct 20, 2018 11:01 am
YW. Chip icon is for configuration and as built programming. Find and select APIM (as built) and click play.
Kugaman
Post by Kugaman » Sat Oct 20, 2018 6:08 pm
Semiho Thank you for all your help, very much appreciated, if that works you have made my day :P :P :P
VictorKitching
Vehicle: Ford Kuga Diesel 2.0 180hp 2016
Post by VictorKitching » Thu Nov 29, 2018 9:15 pm
set * to
I have just used the information to activate a after market camera on my 66plate Kuga.Have set the code to B ie camera with PDC but the centreline and guidelines are missing do you know the code for the activation.Thank you for the help.
12voltWILL
Vehicle: F150, 5.0L v8/285HP, 2015
Post by 12voltWILL » Fri Nov 30, 2018 12:02 am
The guidelines come from the camera itself. Some aftermarket cameras have them and some don't. There is no way to activate them.
VictorKitching
Post by VictorKitching » Sun Dec 02, 2018 9:03 am
Thanks for your reply,I have the guide lines generated from the camera the lines I"am after are the active guidelines generated by the steering angle.
