Hi everyone,
I have a problem with Ford Everest 2.0L Titanium 2018MY when I read data with Forscan (v2.3.17)
I don't see BCM module in configuration menu (I tested with 3 same model cars)!
and Forscan cannot "run service procedure" with PCM module too (It's always interrupted)
I checked as-built data on www.motorcraftservice.com/AsBuilt for VIN: MNCAXXMAWAJU56427 but I still see BCM data (Lines 726-xx-xx)
So Forscan cannot read BCM module on new Everest model yet, can it?
Please help me, thanks!
Cannot find BCM configuration on Ford Everest 2.0L Titanium 2018MY
- Vehicle: Ford Ranger Wildtrack 3.2 2017
- Vehicle: Ford Everest Titanium Plus 2.0L 10 AT 2WD
Re: Cannot find BCM configuration on Ford Everest 2.0L Titanium 2018MY
Same problem here, I have the Everest 2.0 L MY2018 as well but cannot find the BCM and got interupted everytime I try to start the PCM. Maybe we would need to wait for next update?
I guest the database has been updated on FORScan for Windows version 2.3.19 beta or later
https://forscan.org/download/FORScanSe ... 9.beta.exe
Hi All,
I'm in Thailand and have the 2018 Titanium+ 2.0L. Using the 23.1.9 version tried to change the 12volt power points to shut off within 5 seconds of turning the ignition off without success. If anyone has the correct codes for this mod, please let me know.
Use Forscan 2.3.19 version (BCM (BdyCM))tienbamboo wrote: ↑Sat Oct 13, 2018 2:56 pmHi everyone,
- Vehicle: Ford Everest SUV, deisel 200 horsepower, 2018
Did you use ELM 327? Instead you better use ELS 27 obd it can detect your BCM
