Understanding the Codes that are changed
Rockin S
Vehicle: F350 6.7 Scorpion 2015
Post by Rockin S » Wed Oct 03, 2018 11:01 pm
New to Forscan and Ive done a ton searches and watched several Videos, but I cant find the info Im looking for. so, If the numbers you change is the 9338 in the following code **** 9338 **** , Does the software automatically change some of the Numbers in the **** area?
And can some one explain this to me? Like what does it do?
Front Lamp Outage On (LED-Hyperflash)
Front Lamp Outage Off (LED-Hyperflash)
Rear Lamp Outage On (LED HyperFlash)
Rear Lamp Outage Off (LED HyperFlash)
Ptrck600
Vehicle: F150/3.5/2016
Re: Understanding the Codes that are changed
Post by Ptrck600 » Thu Oct 04, 2018 3:21 am
If you install an LED bulb where an halogen bulb normally goes in the turn signal you will end up with a hyper flash. Meaning the bulb will flash 2 to 3 times faster than it should. Also you could end up with a bulb out warning if you use LED in the headlight or brake light or turn signal. Because your bcm can detect a LED being lower resistance than a halogen bulb, in turn giving a false reading of bad bulb/bulb out. To use LED without problems you can turn off bulb out detection.
Ptrck600
Post by Ptrck600 » Thu Oct 04, 2018 4:49 am
Also if you are trying to change tank size you would change
IPC
720-01-02 **** 9338 **** For a 65 gallon tank
Just change the four middle numbers leave the **** bits original.
Hit write
It will give you a warning that the checksum is incorrect, meaning the last two digits/bits
Forscan will calculate and change it when you hit ok
