2016 F-450 SPEED LIMITED TO 74MPH
thecabletek
Vehicle: Ford F-450 V-10 2016 Bucket Truck
Post by thecabletek » Wed Sep 26, 2018 7:37 pm
The company I work for has used another company called DERIVE to install their engine software add on that makes the top speed at 74 mph and changed the rpm levels a tad. Can someone on here tell me what PCM module this under so that maybe I can adjust this speed limit up some so I don't get ran over on the interstate system? Just don't know where this is at and would to disable it all together if this is possible.
ke5adb
Vehicle: 98 F150 4.6
Re: 2016 F-450 SPEED LIMITED TO 74MPH
Post by ke5adb » Thu Sep 27, 2018 1:02 am
Derive Systems is Bully Dog/SCT. If I put an SCT X4 tuner on my truck, it allows me to set a governor. I don't mean to sound like an ass, but if you don't own it, you shouldn't be messing with it. Companies govern their trucks for a reason, and if you go in and change it, I'm willing to bet they will know via gps tracking.
'98 F-150 4.6L V8 4R70W 3.55 2wd
'00 F-350 6.8L V10 4R100 3.73 2wd
'85 F-350 5.9L Cummins G360 5-speed, 4.10 2wd
'18 HD Streetglide
'99 ZX-9R
