*Help* Climate and Radio Preset Issue
vhoo
Vehicle: Ford Edge, Sport V6, 2014
Post by vhoo »
Ok, so I upgraded my Sync 2 to Sync 3. I have a 2014 Ford Edge Sport, the APIM I have is from a F150. I was missing the Climate and heated seats.I searched the forums and was able to get the icons, but they don't work, same things goes for my radio presets; they do not work as well. Below is my APIM codes, can anyone take a look and help me figure out what's wrong?
Current Codes -
7D0-01-01 - xxxx-xxx3-x3xx - HD Radio/Dual Zone AC/Heated Seats
7D0-01-01 - xxxx-x2xx-xxxx - Climate Icon
7D0-04-01 - xxxx-xxx2-xxxx - Climate Quadrant
Thanks in advanced for the help.
vhoo
Re: *Help* Climate and Radio Preset Issue
Post by vhoo »
Ok, so it seems this issue has been around for some time now concerning the APIM Climate issue with the F150. Below is a YouTube video and post showing the problem I am having. Again, I can turn on the icon using FORScan but the temperature does not show and all the buttons on the interface do not work, same goes for the stereo preset buttons; you can't switch to different stations.
https://youtu.be/8s35y6Bsmp4
https://www.fordf150.net/forums/viewtopic.php?t=121462
I am still looking for a fix for this issue and will post it once I find something out.
vhoo
Post by vhoo »
So I've been searching the F150 forums about this and a possible fix and it seems it depends on the model F150 you have that shows the option available. So I wonder if we can get a screen shot of anyone with the option to post there APIM settings so the community can try to figure it out. if anyone knows someone with the Sync 3 climate control option please post it to this thread. Thanks
Vehicle: *** Ford ***
Post by f-wolf »
Have a look here ... :?:
Item Nr. 88-89
https://docs.google.com/spreadsheets/d/ ... =815852466
vhoo
Post by vhoo »
Thanks for the info f-wolf!
kingminivan
Vehicle: Ford Edge, 3.5L V6/285hp, 2014
Post by kingminivan »
Did you ever resolve this issue? I’m having the same problem on a 2014 Ford Edge SEL where I can see the climate menu, but depending on my settings, I either can’t use any of the buttons or I can’t get temperature feedback. Would love to know if you found a resolution.
kingminivan
I have resolved this same issue on my Ford Edge 2014 SEL, if you post your as built forscan currently on the APIM, I may be able to tell you what you need changed.
CobraTyler
Vehicle: F-150, 6.2L, 2014
Post by CobraTyler »
I'm having the same issue, the climate control buttons don't work and the present buttons don't work. Mine is an F150, did you find a fix?
th2408au
Vehicle: 2017 Mustang
Post by th2408au »
does anyone know how to enable the in cabin temperature setting on the sync 3 home screen as shown on the attached photo
SYNC_3_Screen_Front - Copy.jpg (120.38 KiB) Viewed 1572 times
Mine
Vehicle: Mustang, 5,0, 421 PS, 2017
Post by Mine »
7D0-04-01 xxxx xxx* xxxx
Set 0 for dual temperature
Set 1 for single version
Best Regards
Mine
