Remove the chime sound when the door is open and engine is off in a Mustang ecoboost 2017
74lobster
Vehicle: Ford Mustang ecoboost 2017
Post by 74lobster » Sat Jul 07, 2018 3:55 pm
Excuse the question: to remove the chime (unbearable sound) when the engine of the car is off and the door is open, with the program and the interface forscan, what are the values of IPC built in 0720-01-02 that must to be inserted ?
Tell me something about yours values, I found xx1x xxxx xxxx on the internet but keep playing the same.
Among other things, the forscan mask for this parameter makes me see 2 pairs of quatrains and not 3...
My original values are: 0C83 12CB
If someone managed to silence it could you send me the right complete values ?
My Mustang is 2017 ecoboost AT, italian version, keyless, may be are there any other parameters to change to silence the chime ?
Thank you all for your attention.
menib
Vehicle: FORD Mustang GT
Re: Remove the chime sound when the door is open and engine is off in a Mustang ecoboost 2017
Post by menib » Sat Jul 07, 2018 9:08 pm
you are right , it must be 720-01-02 xx0x xxxx , I think now you have standard 0C93 12DB or as you write 0C83 .... then try 0C03 12 , do not worry , always you can back to 9 or 8 if it will be not you expected ,if there is 9 , put 1 , if 8 put 0, instrument cluster reset after programing and default language will be setup after that , then recheck it in menu after all
74lobster
Post by 74lobster » Sun Jul 08, 2018 7:32 am
thanks a lot for your answer.
Practically I can try to enter these values:
0C13 12DB
or
0C03 12DB
Correct?
The forscan after writing the modification tells me to recycle the start mode, so I press the button start to shut off the light inside and then I re-press it again to finish the recycle and re-light the button, is it so?
Thanks in advance.
74lobster
Post by 74lobster » Sun Jul 08, 2018 11:38 am
Finally I succeed to mute the chime door with these settings:
IPC AS BUILT
720-01-02 0C03 124B
720-02-01 ED40 3C94 1C43
Thanks everyone for the help gave me.
Nix2
Vehicle: Ford Mustang V6, 3,7L/305HP 2016
Post by Nix2 » Tue Jul 10, 2018 3:14 pm
Hello
Can I try to enter these values for my older Mustang - My 2016 ?
IPC AS BUILT
720-01-02 0C03 124B
Best Regards ! Nix
74lobster
Post by 74lobster » Wed Jul 11, 2018 7:54 am
Why not ?
Take a not of the standard values you have and try to change them with these new one...
I realized that the chime is inserted or not even depending on the headlights that you have selected, with the lights in the AUTO or off position does not sound, while in other positions yes, so it may be that we also know some other parameter to change to silence the chime also in relation to the various types of lights turned on...
ThatOneDude
Vehicle: 2012 Ford Expedition 5.4L 3V 4WD
Post by ThatOneDude » Wed Jul 11, 2018 2:17 pm
A reminder chime for parking lamps or headlamps has been standard for decades. The recommended silencing method is to turn off your lamps.
1996 Lincoln Town Car (For Sale)
2003 Ford Crown Victoria Police Interceptor (For Sale)
2007 Ford F-150 SuperCab 5.4L 3V 4WD
2011 Ford Crown Victoria Police Interceptor (For Sale)
f-wolf
Vehicle: *** Ford ***
Post by f-wolf » Wed Jul 11, 2018 10:05 pm
Hello
Go to item 56 on left side on page :
https://docs.google.com/spreadsheets/d/ ... =815852466
Nix2
Post by Nix2 » Fri Jul 13, 2018 12:02 pm
It's done!
Thank's
IPC AS BUILT
0720-01-02 xx0x xxxx xxxx
