Enable Auto lock on Ford Fiesta MK8
metalzone
Vehicle: Ford Focus, 1.0 Ecoboost, 125Hp, 2017
Re: Enable Auto lock on Ford Fiesta MK8
Post by metalzone » Mon Dec 03, 2018 10:57 pm
Laaasse,
Can you tell how the dealer could do it? My Ford dealer don't seem to know how?!
Dragunov
Post by Dragunov » Wed Dec 19, 2018 12:50 pm
Here they don't know this aswell.
So we need to do it ourselves
st90
Vehicle: Fiesta ST 2018
Post by st90 » Mon Jan 14, 2019 9:24 pm
have you successfully activated the automatic lock now , on mk8 fiesta?
thanx
timmibaer
Vehicle: Fiesta, 1.0 eco boost 74kw, 2016
Post by timmibaer » Tue Jan 15, 2019 4:19 pm
I have done it :D .
It will work with the newest release of FORScan (2.3.19).
You have to change only one value in IPC (AS-Built format)
720-01-01 xxx* xxxx xxxx
If Autolock Control (AC) is disabled the value of * must be even (hex 0 2 4 ... c e)
To enable AC you must increment the value by 1 .
After writing the new value to IPC you will find a new point under car settings where you can enable or disable Autolock.
Don't forget to save your original IPC settings before changing any value.
Regards
st90
Post by st90 » Tue Jan 15, 2019 5:19 pm
Thank you for your answer,
I will try
dine_nasty
Vehicle: Focus Mk4, 1.0L, 125 Cv, 2019
Post by dine_nasty » Wed Jan 16, 2019 11:49 am
I will try
Hello
Have you try ? and ?
st90
Post by st90 » Wed Jan 16, 2019 9:14 pm
hi,
not yet , i have to fixe my laptop befor , next week maybe.
dine_nasty
Post by dine_nasty » Thu Jan 17, 2019 11:41 am
Hello
Ok I wait, hope you can try !!
laaasse
Vehicle: Fiesta mk8
Post by laaasse » Sat Jan 19, 2019 8:29 am
Laaasse,
Sure,
Tell them this: FDRS -> IPC -> Service Functions -> Autolock Configuration
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Post by davetcollection » Mon Jan 21, 2019 9:14 am
I have done it :D .
Regards
So, this way did not work, error writing code at 13%.
I contacted the guys here at Forscan and they sent me 2.3.20 BETA and it works a treat!!!
There's no coding needed they are now just drop down menus in both the BCM and IPC to enable.
Also enabled Heated Seat and Heated steering wheel in the Sync 3 screen, both working 100%
Auto Lock enables at 20KPH
Thanks again to the Forscan guys
