Sync 3 theme and splash screen ST
Gustavo Baço
Vehicle: 2019 Smax 2.0L Diesel 190Bhp
Re: Sync 3 theme and splash screen ST
Post by Gustavo Baço » Thu Sep 19, 2019 6:51 pm
ThomasD1962 wrote:
Sat Aug 04, 2018 7:40 am
There are five themes (as I understand it); Timeless (which is standard), Classic (same but more colors), GT, Lincoln Timeless and Lincoln Next.
ST doesn't have it's own theme, just the start and end screens.
And here are the numbers!
7D0-03-01: xxxx 00xx xxxx - Ford Classics theme
7D0-03-01: xxxx 01xx xxxx - Ford Timeless (default)
7D0-03-01: xxxx 04xx xxxx - Ford GT performance
For the Lincoln theme’s first do 7D0-01-02: 8xxx xxxx xxxx
7D0-03-01: xxxx 02xx xxxx - Lincoln Timeless (Gold Theme, Black Icons)
7D0-03-01: xxxx 03xx xxxx - Lincoln Next (Gold Theme, White Icons)
Splash screens:
7D0-02-01:
Standard Ford logo; XXXX 0106 XXXX
Lincoln logo; XXXX 0401 XXXX
Lincoln Black Label logo; XXXX 0301 XXXX
Ford Raptor logo; XXXX 0501 XXXX
Ford Mustang logo; XXXX 0601 XXXX
Ford GT350 logo; XXXX 0701 XXXX
Vignale Classic; XXXX 0801 XXXX
Ford GT350R logo; XXXX 0901 XXXX
Ford Performance ST logo; XXXX 0B01 XXXX
Ford Performance RS logo; XXXX 0C01 XXXX
Ford Performance GT logo; XXXX 0D01 XXXX
Lincoln Continental logo; XXXX 0E01 XXXX
You're welcome!
If anyone cares, these codes work fine with a 2019 Ford Smax. Thanks to all.
From Portugal
Thanks to all & drive safe.
Gustavo Baço
terrytuper
Vehicle: 2015 Ford F-150 platinum 3.5 liter ecoboost engine
Post by terrytuper » Wed Oct 16, 2019 2:03 am
There is an easier hack then this with many different themes available to select from and all on the Screen so you can change them without even connecting to your vehicle. Follow instructions in video
https://www.youtube.com/watch?v=7aVOJ-G ... ture=share
lucajordi
Vehicle: Ford Kuga 1.5 Ecoboost 2018
Post by lucajordi » Wed Oct 16, 2019 3:11 pm
But this changes are lost after a restart...
To set it fix you need to change the code!
Iker Anduiza
Vehicle: ford focus mk4
Post by Iker Anduiza » Fri Oct 18, 2019 1:07 am
Splash screens:
7D0-02-01:
You're welcome!
can you send me the spreadsheet please? I don´t know where search.
thank you
sacem52
Vehicle: F150, 3.5 ecoboost, 2016
Post by sacem52 » Sat Oct 19, 2019 2:21 am
Is there a reason why this thread lists the Lincoln Black Label theme as: (Lincoln Black Label logo; 7D0-02-01: xxxx 0301 xxxx) /// and the My 2015-2019 F150 as-built decoding spreadsheet lists it as: (7D0-02-01: xxxx x3xxx xxxx)? Is there a difference between the 0301 and the x3xxx? I've tried programming my APIM both ways and the Lincoln Black Label theme seems to work correctly both ways.
One side note I've noticed... The ambient lighting colors listed in the sync 3 ambient lighting section changed on my 2016 F150 Platinum. For example the first color listed on the Lincoln theme is white and previously it was ice blue... however, when white is selected the color displayed is still ice blue. This alone is the reason why I tried the Lincoln theme both ways (x3xxx & 0301) and it did not effect the colors listed after the change to the Lincoln theme.
caperj
Vehicle: Ford 3.5l ecoboost
Post by caperj » Mon Nov 25, 2019 3:07 am
Itachi
Vehicle: Ford Focus 2,0L/250HP 2017
Post by Itachi » Sat Jan 04, 2020 10:18 pm
Hello. And anyone knows which parameters to change to activate the ST logo (start and end) in SYNC2
