2017 Escape Titanium mods
MuskiesFan4Ever
Vehicle: Escape, Escboost 2.0, 2017
Post by MuskiesFan4Ever »
Has anyone had any luck programming bambi mode, window global open/close, etc mods using FORScan with an OBDLink MX WiFi interface (the red one) on a 2017 Escape?
I gave it a try and it gets to 46% of "Loading block 1/6..." and then says "Operation failed, retrying..."... screen shot attached of the sequence of messages.
Any thoughts or do I just need to use a different interface?
And if it is an incompatible interface what is the most reliable interface to use?
Thanks for any assistance.
WuNgUn
Vehicle: 2019 Escape Titanium
Re: 2017 Escape Titanium mods
Post by WuNgUn »
MuskiesFan4Ever wrote:
Fri Jun 08, 2018 2:24 pm
I dunno about the WiFi unit, but on the BT version, you have to crank up the baud rate of the BT/USB device to prevent these errors.
