2017 f150 trailer brake activation
17whitef150
Vehicle: 17 f150 5.0
Post by 17whitef150 » Tue May 29, 2018 1:10 am
i tryed to used the values from this list, https://docs.google.com/spreadsheets/d/ ... 0/htmlview#
and for the second postion in the second set of four numbers in address 720-07-01 i did not have a 0 or a 6. I beleive it was a 2 if i remember right. Im wondering if these values are correct for my year truck?
Vladsky
Vehicle: 2017 Ferd PHEV
Re: 2017 f150 trailer brake activation
Post by Vladsky » Tue May 29, 2018 8:31 pm
17whitef150 wrote:i tryed to used the values from this list, https://docs.google.com/spreadsheets/d/ ... 0/htmlview#
Howdy .. and WTF? :lol:
This is simple, fundamental Base 16 arithmetic - ADD '8' to whatever value is in that position. Remember - it is HEX:
Trailer Brake Control Module enabled
IPC 720-07-01 xxxx x*xx xxxx if your as-built is 0, use 8. If your as-built is 6, use E
Trailer Brake Controller Gain Setting enabled
IPC 720-04-01 xx4x xxxx xxxx
Perhaps you should READ the Tutorial - yer understanding appears somewhat lacking. http://forscan.org/forum/viewtopic.php?f=16&t=4393
Additionally - you should NEVER be saying " ... I believe ..?". You should KNOW. Refer to yer backups if in doubt to confirm. Screenshots before changes work well too.
If yer unsure about what you are doing - don't use this tool, as the consequences of fekking something up are potentially dire.
BTW - the trailer brake config is the same from 2015-up; yer 2017 ain't special :lol:
Salut
Vlad
jkboud
Vehicle: 2017 Ford Expedition 3.5 Ecoboost
Post by jkboud » Sun May 12, 2019 1:07 am
Thank You Vladsky for posting this info. I used it to activate a trailer brake control module on my 2017 Expedition. I was a little nervous changing the as built codes, but they worked perfectly!!
