unable to calibrate guide lines 2011 ford edge
rjcapp
Vehicle: Edge, 3.5L, 2011
Post by rjcapp » Mon May 07, 2018 12:53 pm
I replaced the backup camera on my 2011 ford edge....successfully connected to my 2011 ford with foscan but the calibration for the guide lines is not available. Anyone else have this issue or figured out how find / add the cal?
purchased the camera off of ebay...it works except no guide lines
IMG_8460 2.jpg (894.43 KiB) Viewed 3880 times
twisterrescue
Vehicle: 2003escapeltd
Re: unable to calibrate guide lines 2011 ford edge
Post by twisterrescue » Tue May 08, 2018 2:09 am
IS IT a FORD camera or a china clone guide lines are controlled using lin data to camera
twisterrescue
Post by twisterrescue » Tue May 08, 2018 2:10 am
rjcapp
Post by rjcapp » Tue May 08, 2018 11:51 pm
sorry for the delayed response...thanks for the response
china camera purchased on ebay....
I cant even try the calibration for lines - I downloaded forscan 2.3.14 and the test for "BdyCM Rear Camera Calibration" is not available
should it be there?
I can connect fine, i was able to clear all DTCs', I need the BdyCM Rear Camera Calibration test to show up
Or if I bought the overpriced ford camera and installed a ford camera Forscan would know and the "BdyCM Rear Camera Calibration" test would be available?
Shouldn't the calibration be there no matter what camera is installed?
rjcapp
Post by rjcapp » Wed May 09, 2018 4:21 am
Support informed me The function you need is called "Local Interconnect Network New Module Calibration".
I will try it tomorrow
rjcapp
Post by rjcapp » Wed May 09, 2018 2:21 pm
did not work with no Ford camera....oh well I am fine the way it is
mikenlaura
Vehicle: 2011 Lincoln MKX
Post by mikenlaura » Wed Jun 27, 2018 2:03 pm
FYI, I had to replace the camera in a 2011 MKX, the new camera had no guide lines also. I just performed the "Local Interconnect Network New Module Calibration" and now the guidelines are back. I did buy a Ford/Lincoln camera because the Chinese clone did not fit. I have no idea why Ford's camera cost 10x as much though.
jimifun1
Vehicle: Lincoln, MKX, V6, 305 hp, 2012
Post by jimifun1 » Mon Jul 02, 2018 9:30 pm
I have a 2012 Lincoln MKX same as your Edge. I tried to calibrate my camera too but it would not hold the calibration. After the second shift into reverse it would be gone. Took it to the Ford dealer and he had the same problem but gave me some hints to look for corrosion in connectors so I brought it home took the only one that I knew was exposed to moisture and it looked o.k.. So I hooked up Forscan again but this time I not only recalibrated the camera {BCM} Body Control Module on my car but also I was getting a code for my Parking Aid Module {PAM} so I recalibrated that too. Presto, Camera works, zoom function works and warning colors are on the camera too.
Alot of these functions take different readings from other sensors. In this case the camera takes reading from the Parking aid module and it can't install the lines if it doesn't get good info on how close it is to something, so it does nothing.
shauggy
Vehicle: 2012 Ford Edge SEL
Post by shauggy » Fri May 31, 2019 7:39 pm
Thanks, that was just the info I needed to get the lines back on my 2012 Edge!
jorgimbo
Vehicle: Ford Explorer Limited 2011
Post by jorgimbo » Mon Jun 03, 2019 1:27 pm
How do you recalibrated pam ij forscan?
