navigation
FFMartin91
Vehicle: 2013 Ford F150 FX4 3.5 Ecoboost
Re: navigation
Post by FFMartin91 » Tue Mar 12, 2019 2:32 am
Since I've seen some people having issues with adding nav to their sync with 3.10, here is everything you need.
3.10 Nav Files:
https://mega.nz/#!i6hxGAia!gDzNY4mBHmSO ... hVbLxj7TXc
Nav Patch:
https://mega.nz/#!zmBWxCBC!Xgpa4AM3R5_A ... YFh8s5VJgs
Download and extract 3.10 Nav Files onto USB drive and install in vehicle. Should automatically install once USB is plugged in.
Download Nav Patch and place onto USB and plug USB into vehicle. Go to settings>display>wallpaper>add>Nav Patch and then press the thumbnail to enable.
Then run forscan, switch the code, and insert nav card. Should be good to go after that with no resetting needed.
norma250
Vehicle: F250, 6.7L, 2015
Re: navigation
Post by norma250 » Wed Mar 13, 2019 1:32 am
I edited the APIM and added the navpatch file but it still only has compass, it is not asking for the card to be inserted and no other nnav menu reference. I must be missing a step and or out of sequence. Even tried master resest a few times and still no nav menu and or ask for card to be inserted. I checked forscan and it states APIM nav enabled
semiho
Vehicle: Focus Mk4 St-Line Ecoblue A/T
Re: navigation
Post by semiho » Wed Mar 13, 2019 8:05 am
A master reset is necessary.
lenko
Re: navigation
Post by lenko » Wed Mar 13, 2019 2:24 pm
You probably did, but when you edited the APIM with the "4" in the second position of 7D0-01-2 x4xx xxxx xxxx, did you click on write and follow the instructions as Forscan rewrote the module? Maybe just enabling on the other screen doesn't work and you need to enter the "4" manually.
norma250
Re: navigation
Post by norma250 » Wed Mar 13, 2019 11:46 pm
for all to date thanks in helping but per latest post I did review, write and ensure the 0 was replaced with a 4 in APIM (as built) and that nav was enabled in APIM menu. Still no nav change. even reset to 0 and disabled then back to 4 and enabled. any suggestions?
lenko
Re: navigation
Post by lenko » Thu Mar 14, 2019 1:31 am
Were you able to execute the Navipatch.png file? That sometimes does not take right away.
norma250
Re: navigation
Post by norma250 » Thu Mar 14, 2019 2:47 am
I loaded the navpatch file thru the display wallpaper menu option. No error message but also nothing else I noticed after loading in terms of screen or function difference. Should I load it in a different way or sequence such as after APIM edits or other since it has been an issue as you indicate?
FFMartin91
Re: navigation
Post by FFMartin91 » Thu Mar 14, 2019 2:50 am
Did you install both files? NavPatch and the NavFiles? Did you go to the display settings and add the NavPatch and press the thumbnail to get the "ENABLED" message?
Negative, I never had to with the way I posted a few posts up :D
norma250
Re: navigation
Post by norma250 » Thu Mar 14, 2019 3:27 am
Hi all let's call it three times the charm. Reloaded png file a few times and now all is working well. Thanks again - all will be happy with this feature now enabled. Thanks again for support and patience
FFMartin91
Re: navigation
Post by FFMartin91 » Thu Mar 14, 2019 3:30 am
Glad to hear it worked
