2018 F150 Auto Start Stop
gregf150
Vehicle: Ford F-150 xlt v8 2018
Re: 2018 F150 Auto Start Stop
Post by gregf150 » Fri Feb 08, 2019 1:23 am
Didn't work for me. I did the bambi mod and it worked fine. I used 726-48-02 x0xx xxxx xxxx Anyone have any ideas? 2018 F150 XLT 4x4 SC Sport
rdatkins
Vehicle: 18 F150 3.5 Twin Turbo
Post by rdatkins » Fri Feb 08, 2019 1:41 am
I ended up going with auto stop eliminator. Little pricey. Well worth it, makes it so you can shut it off and leave it off after restarting but you can still turn it back on if you want.
https://www.autostopeliminator.com
thebeav2004
Vehicle: 2018 F150 Lariat Supercrew 5.0
Post by thebeav2004 » Wed Apr 17, 2019 1:05 am
Auto Start/Stop Disable - by disabling BMS (Battery Management System). I changed the BCM 726-48-02 to x0xx xxxx xxxx. Now auto stopstart menu says Engine On due to Vehicle Charging. Should be worried that my alternator is running all the time(I believe the new F150s have a smart alternator which only operates on demand)? What other hazards could be an issue of doing it this way ? Any thoughts would be great. Thanks in advance.
rdatkins
Post by rdatkins » Wed Apr 17, 2019 1:16 am
I would be. Forscan works to disable it by giving bad Info to the computer. I just got a plug in from autostopeliminator.com and now I don't have to worry about it
ted22
Vehicle: escape 2.0 2016
Post by ted22 » Wed Apr 17, 2019 4:38 pm
Has anyone tried unplugging the button on the dash? I read on another forum that if you can unplug the button, but have not tried it. I have a friend with a leased vehicle that does not want to re-program.
Lev35
Vehicle: 2020 Ford t
Post by Lev35 » Thu Nov 19, 2020 5:06 am
on my 2020 it did not work, I entered the value 0 into the second cell, but this value remained constant, but the engine stop still continues :?:
