Ford PATS Key code
gotty101
Vehicle: Ford Focus RS Mk1
Ford PATS Key code
Post by gotty101 » Tue Feb 13, 2018 8:48 am
Hope someone can help me.
Im building a kit car based on an ST170 engine from a ford focus. The problem is the engine did not come with the keys, and now the breaker i bought the engine off is not responding to my messages. So is it possible to re code the PATS system with out any keys, or does anyone know if i can send the ecu off to get keys coded for it?
Ecu EEC-V
Ecu code 3NFA
Hopefully there is a way this can be done.
Many thanks
Trev
speedyhodge
Vehicle: Focus ST170 2003
Re: Ford PATS Key code
Post by speedyhodge » Wed Mar 14, 2018 3:03 pm
You can use forscan to write new keys you will need to activate the extended licence.
once you get an outcode from forscan you can go to the following site http://www.autokeyprog.com/service.php register costing nothing and use there patcode generator.
you will get an incode! enter this when asked on forscan and you are then able to program new chips! I believe they have to be virgin 4d60 chips.
hope this helps
Dex316316
Vehicle: 2011 Ford F-250 6.7 power stroke
Post by Dex316316 » Sun Mar 18, 2018 3:27 am
Will this work on f250 also.
pook
Vehicle: FORD GALAXY MK3 2.0 140KM 2012
Post by pook » Sun Mar 18, 2018 12:30 pm
How can I get income code for Ford Galaxy MK3 2012? This link doesn't work for my car.
My outcome code looks like this: 1040 B5E976 000000
Joebloggs
Vehicle: Ford Galaxy
Post by Joebloggs » Tue Oct 23, 2018 8:45 pm
I have te same problem. My Key starts with 1040, this is not registered in autokeygen.
How can I generate my incode now?
Markus
talbot_sk
Vehicle: Mondeo 2.0 TDCi 120 kW 2011
Post by talbot_sk » Wed Sep 11, 2019 8:37 pm
Hi, my outcode starts with 1040 too. Does anybody know how to generate proper incode? Thank you.
hueypilot
Vehicle: 2017 Ford Police 3.5L
Post by hueypilot » Tue Sep 17, 2019 12:24 am
Maybe you can delete the PATS via ebay, https://www.ebay.com/sch/i.html?_from=R ... 095919823b
ubertino
Vehicle: f250 7,3 diesel 2001
Post by ubertino » Sun Oct 20, 2019 7:00 am
Hy guys i'm located in italy i lost my only key left on my f250 superduty 2001 ? Will I be able to erase both he keys and add a new one via forescan ?
Ford dealers in europe don't assist amercan ford.
Thanks for support
